R55 Check engine light
Old Sep 8, 2011 | 10:57 AM
Sevenrider's Avatar
Sevenrider
Check engine light
2011 Clubman S Yesterday ck engine light came on with a fuel cap message.Cap was on correctly. Restart car light went out.Today same thing only light not going out.
Called dealer "lot of issues with 11's take to dealer to reprogram"200mi ride one way one of the down sides of owning Mini not alot of dealers.
Said it would be safe to drive,so I may wait for a convenient time.
Anyone else with this issue? 8000mi on car.
Old Sep 8, 2011 | 11:42 AM
bluefox280's Avatar
bluefox280
As long as the CEL does not flash, yes it's safe to drive.
Since it's so new, it's adventaeous to send it back to the dealer to perform the tests / diagnostics under warranty.
If you want, you can head to a local auto store, borrow their OBDII generic scanner and see what fault codes are present.
Record those, and post back your exact fault code numbers...
- Erik
Old Sep 8, 2011 | 12:47 PM
Sevenrider's Avatar
Sevenrider
I'll do that thanks
Old Sep 8, 2011 | 02:25 PM
rum4's Avatar
rum4
I had the same issue with my 2011 and had to take to dealer for a fault sensor. Repaired under warranty. It is an hour and a half journey for me, so I agree sux to have to go back so soon. Mine happened with less than 7000 miles on it
Old Sep 8, 2011 | 04:44 PM
Sevenrider's Avatar
Sevenrider
had it ck at auto zone code PO442.
Warning the same "fuel cap" cel remains on.
doesen't seam to effect the way car runs.
Old Sep 8, 2011 | 07:45 PM
bluefox280's Avatar
bluefox280
* Mini DTC P0442 - EVAP Emission Control System (small leak) Leak Detected
Well, the EVAP leak could be as easy as a non-sealing gas cap to a crack in the EVAP vacuum lines.
Most EVAP problems don't after car performance, but it does affect gas mileage as the leak allows gasoline vapors to escape.
- Erik
Old Sep 9, 2011 | 05:00 AM
Sevenrider's Avatar
Sevenrider
Thanks Erik/all I will follow-up after I find out.Mark
Last edited by Sevenrider; Sep 9, 2011 at 05:02 AM. Reason: include other responders
Old Sep 21, 2011 | 10:24 AM
UAL_Kingpin's Avatar
UAL_Kingpin
What was wrong with the car?
Old Sep 21, 2011 | 12:53 PM
Sevenrider's Avatar
Sevenrider
Haven't taken to dealer yet.Will post after I find out
Old Sep 21, 2011 | 03:03 PM
UAL_Kingpin
I am taking my 2011 back to the dealer tomorrow. I have had 3 check engine so far. The first one could have been that I forgot to tighten the filler cap. The second one went away on its own after several days. The recent one went away by itself the next day. While I am at the dealer, I am going to have them check why the speaker makes a loud pop sound once in a long while. Several 2011 owners who have the HK stereo have this problem.
Old Sep 22, 2011 | 08:53 PM
ggonzale's Avatar
ggonzale
I have the same problem and instead of the fuel cap ended been the premium gas I was using. For some reason my clubman doesn't like Phillips (probably the additives they use) which I use on my wife's car
Old Oct 14, 2011 | 05:27 PM
Sevenrider's Avatar
Sevenrider
Mice built nest ontop of fuel pump and chewed a tiny hole in what appeared to be part of the plastic casting (alittle tit).The dealer fix was a new pump $600.
Since I had driven the car 1000 mi in that condition and after seeing the damage I thought about my father-in law a (great mechanic) and what would he do.He would improvise of course!
After talking to the tech and from what I seen the hole was pluged cel turned off after another 1000 mi no cel no gas smell.paid $75 and was on my way.
Got lots of mice traps on hand.
Old Oct 15, 2011 | 12:18 PM
cccplus's Avatar
cccplus
yikes, rats/mice... i'm glad we have many stray cats in our neighborhood
Old Oct 20, 2011 | 05:40 PM
capt fred's Avatar
capt fred
As posted on another thread (that no one responded to) My engine lite came on my 2011 and I had it checked. Found the following codes;
2947---coolant temp sensor
29dc---charge air sensor
2c58---charge air pressure
Cleared the codes and hoping for the best.
Old Oct 20, 2011 | 06:41 PM
Sevenrider's Avatar
Sevenrider
Did you take it to dealer?should be covered .Mine was due to mice as I stated not covered under warranty
Old Oct 20, 2011 | 06:55 PM
UAL_Kingpin
They had to replace the coolant temperature sensor on my car. The car only had 2,500 miles at the time.
Old Dec 23, 2011 | 11:20 AM
petery's Avatar
petery
I was driving yesterday doing some Christmas shopping and guess what? I see the check engine light in the dash, I don't know if it was there when I started the car but it just came on out of no wehere. I put little over 5100 miles on my 2012 clubman S and it went to the dealer this morning to be checked thoroughly. I noticed louder than usual fan noise when I stop the engine so the dealer is looking at the check engine and fan noise, they will call me with the finding later today.
Old Dec 23, 2011 | 12:21 PM
UAL_Kingpin
My engine fan noise was also extremely loud after I turned off the engine.
Old Dec 23, 2011 | 11:26 PM
Danielng0811's Avatar
Danielng0811
I have the same problem when my 2011 Mini Cooper S Clubman was about 2,000 miles. I had it checked at the dealer and end up the thermostat was changed.
Many owners experienced the same problem. I think the thermostat is not in good quality.
Old Dec 27, 2011 | 08:19 AM
petery's Avatar
petery
Thanks UAL_Kingpin and Danielng0811, you guys were both right about the coolant sensor and thermostat, the dealer found the faulty coolant temp sensor and replaced thermostat and added 2 litters of coolant. The fan noise is back to normal
Old Dec 27, 2011 | 08:25 AM
UAL_Kingpin
Check your coolant level. I had to add some coolant after the repair.
Old Dec 27, 2011 | 12:24 PM
petery's Avatar
petery
The dealer added some already but I will go home and check tonight, thanks
Old Sep 20, 2015 | 04:50 PM
BossyR56's Avatar
BossyR56
My engine light came on and they found out codes 2947 and 3786(recall). I have a 2011 with 52K. Im out of basic warranty. However I have an extended powertrain warranty is this covered? And what about the recall?
Old Sep 21, 2015 | 12:59 PM
I would call the extended warranty place first and see if its covered.
Its was a TSB for the sensor dependent on the model , call your local dealership and see it its covered.
Old Sep 25, 2015 | 02:53 PM
hamptup's Avatar
hamptup
Super old thread but a lot of 2011's S models had faulty temp sensors.
BossyR56 your car should still be covered under warranty to fix those problems. I had our temp sensor replaced at 5k and just recently at 42k miles under warranty.
