R50/53 Does anyone have a good tutorial for a DIY Oil Change for an R53?
Old Aug 29, 2011 | 11:25 PM
jennster's Avatar
jennster
I just changed my light switch out tonight and I'm feeling kind of cocky. I did a search but didn't find what I was looking for exactly.
Old Aug 30, 2011 | 03:25 AM
MadisonKobalt's Avatar
MadisonKobalt
The thread people usually follow on NAM is here.
Old Aug 30, 2011 | 04:12 AM
Capt_bj's Avatar
Capt_bj
looks like the pictures are gone on that link
PM me with an e-mail and I can send it to you as a pdf I saved
Old Aug 30, 2011 | 09:10 AM
nitrogen76's Avatar
nitrogen76
I will be doing an oil change this weekend, and can re-make those instructions with pictures unless someone can resurrect the old stuff.
If you read those instructions, i'll make one suggestion: Loosen the canister/oil filter FIRST and let it sit. You'll feel when you've loosened it enough. You'll get a lot less oil on the floor that way.
Old Aug 30, 2011 | 10:55 AM
minimic's Avatar
minimic
i use the topsider oil changer and suck the oil right out of the dipstick tube. its great!
Old Aug 30, 2011 | 11:35 AM
quikmni's Avatar
quikmni
I pre-fit the oil filter element to make it a little easier to start the canister threads when putting it back on. I push the filter element onto the engine block to enlarge (pre-size) the hole in the filter. I then remove the filter element from the block. I push the filter element onto the canister. I then install the canister with filter element onto the engine. This just makes the canister go on a little easier and makes getting the threads started just a little easier.
Old Aug 30, 2011 | 02:27 PM
jennster's Avatar
jennster
Capt, I pinged you for that PDF, thanks for offering. Does everyone prefer the manufacturer's filter or is aftermarket acceptable?
Old Aug 30, 2011 | 03:03 PM
quikmni's Avatar
quikmni
I had always used the OEM filters (Mann/Mahle) but just switched to WIX because it seems to be better than the OEM (more pleats and better end caps).
Old Sep 2, 2011 | 05:53 AM
Mini PoWA!'s Avatar
Mini PoWA!
I just watched the youtube video on this and the demo was a Mini lol> This thing is pretty sweet I might have to give this a try!
heres the link:
http://www.youtube.com/watch?v=CYPH3CMS6-0
Kimolaoha
Jul 5, 2023 01:04 PM
Colt45Magnus
Jul 14, 2019 06:18 PM
Rgoodwin
Tires, Wheels, & Brakes
Apr 21, 2017 10:56 AM
sprp85
Aug 22, 2015 06:16 AM
ludedude
Aug 10, 2015 07:16 PM
