R50/53 So..would you absolutely avoid a 2003/2004 in favor of a 2005/2006
Old Aug 17, 2011 | 01:42 PM
Kahnfucious's Avatar
Kahnfucious
Hey guys,
New to the boards...so I have been reading a lot of the posts, read the motoring purchase guide.. and I am wondering if you guys would be dead set on avoiding a 2003/2004 Cooper S.
The price differential between the '04 and '06 is roughly 2,000 for similar mileage cars as I am seeing it.
Would much rather pocket the cash / keep it for mods and maintenance -- so... thoughts?
I will only buy a cooper with <75k miles...as a reference point.
Old Aug 17, 2011 | 01:46 PM
Professor's Avatar
Professor
As long as it is an S the 03/04 would not bother me. I have a 2004 and have not had any issues out of it.
05/06 would be preferred for the newer supercharger and the shorted gear ratios. 05/06 also have some nice cosmetic options.
Old Aug 17, 2011 | 01:48 PM
JAB 67's Avatar
JAB 67
The principal difference between the 03/04 and the 05/06 is the gearing in the 6-speed getrag transmission; the latter is somewhat better.
Old Aug 17, 2011 | 01:49 PM
Kahnfucious
I am speaking mostly from reliability standpoint -- I knew of the transmission change... the supercharger is new information -- thank you.
So I guess as it gets closer to my purchase I'll have to weigh these out.
Old Aug 17, 2011 | 02:58 PM
ofioliti's Avatar
ofioliti
By "newer supercharger" I think Prof meant "less mileage" rather than "different supercharger." As far as I know, the supercharger did not change.
Old Aug 17, 2011 | 05:21 PM
MI MINI S's Avatar
MI MINI S
'05 & '06 R-53 "S" models have an upgraded Eaton M45 supercharger. The upgrade was coated compressor rotors. They also have the Getrag 6 speed manual transmission with "shorter" gear ratios. If you get a chance, drive a '02, '03 or '04 with the Midlands 6 speed then drive a '05, '06 with the Getrag transmission...the shorter gearing makes a big difference. And the magic is a -15% or -17% supercharger pulley mod.
There seems to be many low mileage R-53's on the market. Take your time, you will find what you are looking for. As with any "forced air induction" engine (supercharger or turbocharger) good maintenance history is the key to getting a sound car. Good luck & keep researching.
Professor's Avatar
Professor
It did change. They came with Teflon coated rotors. The working are the same and not any more or less reliable. The 02/04 uses the 4th gen M45 where the 05/06 uses a 5th gen unit. Again I think the only change was the rotor coating.
Old Aug 17, 2011 | 07:37 PM
hexon's Avatar
hexon
All the first gen S models have 6sp Getrags. Only the 02-04 justa's had the 5 sp midlands. They did change the gearing in the Getrag on the 05-06's though.
Old Aug 17, 2011 | 08:01 PM
ofioliti's Avatar
ofioliti
I was not aware that pre-'05s did not have the coating! Thanks.
Old Aug 18, 2011 | 07:22 AM
thulchatt's Avatar
thulchatt
I have an '04 without any problems at 68k so I would say 03/04 is fine. Mostly depends on the car and how it was treated by the prior owner(s). I also think the '04 transmission ratios and a 15% pulley work just about perfect. The '05 I drove with a pulley seemed to be geared a little low for the power. Others will disagree so it may be just a taste thing.
However, for $2,000 I would go with the 05/06. There were a number of small modifications that would make it worth it.
Really just getting a well maint'ed car is the most important thing.
Old Aug 18, 2011 | 08:29 AM
quikmni's Avatar
quikmni
I had an 03 and now have an 06. The gearing change is an improvement.
The supercharger coating difference is not a big deal. The 03/04 stock supercharger did not have rotor coating and the JCW supercharger for 03/04 did have the extra coating. In 05 they started using the same (coated rotor) superchargers for stock and JCW. The 05/06 have engine mounts that need replacement about every 30,000 miles. The 05/06 have slightly adjustable rear camber. Otherwise the 03/04 and 05/06 are about the same.
Old Aug 18, 2011 | 11:02 AM
CrazyIvan's Avatar
CrazyIvan
The only reason I'd pick a 05/06 over previous years is if it had an LSD if not get the lowest mileage car you can find.
Old Aug 18, 2011 | 11:41 AM
ufomini's Avatar
ufomini
$ 2,000 is not much when it comes to repairs. However, I would get the one that you want. As long as you avoid any CVT MINI's, it is all a Merry Christmas.
By the way, I bought my 06 MCS with 77,000 miles and have absolutely no regrets. There is no other MINI of any year that I would choose over my "Flash"!!!
Old Aug 19, 2011 | 04:02 PM
NightFlyR's Avatar
NightFlyR
I have an 04 MCS 100 K no issues, original clutch, 1 set of brakes, car has been pretty much bullet proof
Old Aug 21, 2011 | 04:05 PM
Cavalier Cooper's Avatar
Cavalier Cooper
Nope, I didn't have the budget to get an 06+ so I focused on finding the cleanest 04/05 I could.
Old Aug 21, 2011 | 04:23 PM
Evasive's Avatar
Evasive
I opted for 2006 myself and passed on a few 03/04 that was a prett good deal. It seemed like reliability was a little better.
Old Aug 22, 2011 | 07:16 PM
CupNCakes's Avatar
CupNCakes
I bought an 04 with 58K yesterday afternoon. Took it in for an inspection today and there is absolutely nothing wrong. Just take your time and you'll know when you find the perfect car
TunedGP
Oct 1, 2015 04:18 PM
Olenska
Sep 18, 2015 09:24 PM
Sc00terbum
Sep 11, 2015 07:17 AM
