Suspension Strut suspension collapse fix
Old Aug 17, 2011 | 07:06 AM
kiko's Avatar
kiko
The front end of my '04 strut suspension mushroomed the metal at the attachment to the car body in the engine compartment so I could not keep the front end aligned.
Is the new generation Mini '07 and newer, (I'm looking at a '11 model) improved in the suspension area?
Specifically has this problem been solved or is there an aftermarket fix available?
Old Aug 17, 2011 | 08:24 AM
luseboy's Avatar
luseboy
I don't know if they have changed anything... but I know you can take a 2x4 and a bfh(big frickin hammer) and get the towers un-mushroomed. Then put on IE fixed camber plates and a m7 stb and you will never mushroom again.
Old Aug 17, 2011 | 08:28 AM
kiko's Avatar
kiko
What are these parts and where do I find them?
"IE fixed camber plates and a m7 stb"
Old Aug 17, 2011 | 02:00 PM
luseboy's Avatar
luseboy
whoops sorry. Ireland Engineering fixed camber plates and m7 tuning strut tower brace. WMW (www.waymotorworks.com) has the best pricing on this stuff.
Old Aug 17, 2011 | 02:14 PM
quikmni's Avatar
quikmni
I would also suspect if your strut tower is badly mushroomed that your top strut rubber bushing is also torn or cracked. The IE Fixed Camber plates are a good choice to help with mushrooming and torn bushing because they offer many benefits over the stock top strut bushing.
- Thicker rubber bushing
- Thicker metal plate
- Increases negative camber by 1.25 degrees to improve handling
- Only costs a few more dollars than the stock mount
Here is a link to the IE Fixed Camber Plate:
http://www.waymotorworks.com/ireland...e-r50-r53.html
Here is a link to the strut brace:
http://www.waymotorworks.com/m7-strut-tower-brace.html
The only issue I have with top strut braces is that I change the oil filter from the top and a brace would be in the way.
Old Aug 18, 2011 | 12:10 AM
KC Jr 54's Avatar
KC Jr 54
Get the Craven STB. MUUUUUUUUUUUUCH better design then the M7 by leaps and bounds. The M7 has a major design flaw, and that is the plate gets as thin as 3/16"s. When talking AL that thickness is not near enough to stop the forces that cause that damage.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
kazyn
Oct 25, 2019 02:34 PM
maestro39
Oct 27, 2015 02:38 PM
Aug 27, 2015 12:25 PM
nomar116
Aug 10, 2015 11:24 PM
