R58 S Coupe tire size.
Old Aug 8, 2011 | 09:02 AM
Herby74's Avatar
Herby74
S Coupe tire size.
I have used 205/55/16 a/s v rated tires on my R53's and R56. Should I use the same size on the R58?
Old Aug 10, 2011 | 12:25 PM
TheOfficeMaven's Avatar
TheOfficeMaven
I would imagine that the tire specs for the R58 Coupe will be exactly the same as for the R53 and R56. The only thing I could see as a problem would be the larger brakes on the JCW Coupe (which probably eliminates the use of a 16" rim and will only work with select 17" rims that have the proper clearence).
Old Aug 15, 2011 | 01:33 PM
PatM's Avatar
PatM
Does anyone know for sure if the Von Max 17 X 17.5 wheels will fit on the JCW Coupe? They are available at the Tire Rack. The offset is 40 MM and the backspacing is 5.86.
Regards,
Pat
Waszak
Oct 21, 2017 05:55 PM
minners
Sep 21, 2015 09:26 PM
Witsticka
Sep 15, 2015 01:33 PM
Sep 2, 2015 12:57 PM
Sep 2, 2015 12:55 PM
