Navigation & Audio Base Radio Good Enough? I think so.
I have a 2011 Clubman S with several options. I didn't elect to add the HK stereo to my car. While I awaited delivery of my car, I worriend that I had made a mistake. I purchased one of the original new MINIs, an R53 in 2002. The sound "sucked," in a word. It was characterized by its lack of clarity and the absence of any bass. Moreover, it lacked power to overcome any real road noise. So I replaced the speakers with Boston Acoustics, used the stock head unit and added an Alpine amp. It was such an improvement I couldn't believe it. So I worried that going with the stock stereo in my new car might have been an error or major proportions.
I was wrong to have worried. While I am not an audiophile, I do like my music and want the sound to cover a reasonable spectrum with lots of clarity -- clear highs and lows that I can feel, not just hear. After about two months with my car I want to report one owner who is very satisfied with the stock stereo and the sound experience it provides. Others may disagree, but for me it works, and I saved $750 to boot.
Add a Jbl ms-8 and a set of 100 dollar(pick your fav) 6.5 inch and 4inch drivers in the doors and 1 inch tweeters in the a pillars and maybe change out the rear speakers for added depth and you will have a great sounding system for $1200 retail that will surpass anything offered by MINI.
check ebay for used a jbl ms-8 and you might be able to pick one up for 400ish and that would drop you to $700/800ish including drivers and tweeters plus supplies for install .
The Ms-8 is easy to install taking a total of 2 hours ,just wire to the speaker pick up in the drivers footwell using the factory harness and the jbl harness that comes in kit and a connection for power and ground.mount the ms-8 under a front seat or on right side of hatch on a r56.
Jbl ms-8 is 11.5 X7.5X2.5 includes a 30wattx8ch 4ohm/18wattx8ch 2ohm amp ,remote control, active sound processor with eq and is expandable giving you the option install amps,subs,center channel , a/v and still use your factory head unit and all factory controls and options like bt,nav , sat ,connect
Pm me If you have any questions on installing or info on a ms8 .
Very happy too with my base system. I've changed out my door speakers for Polk Audios, added a very small JVC powered subwoofer in the back and channel swapped. Did it all myself, have about $250 invested, and it'll blow away any factory HK system. I've said before, it's not how many watts you have, it's how well you use them.
I certainly don't claim to be the arbiter of what is and what is not anything. At the same time, when I started this thread, I was talk about the base radio system that comes with the car, unmodified. I was simply saying that in my previous R53 the sound quality was so bad I needed an upgrade -- bad! The base radio (non-HK) in my new R55S has very satisfying sound. It has not been modified by switching out the speakers or adding a subbwoofer. While others might find some pleasure and value in these mods, I don't see the need to spend $ on this. There are other ways to improve my MINI that I will spend on.
Uh, yea...it's non H/K or Hi-Fi...so that makes it a base system, or should I be more defined by calling it "Boost", hehehe....
I have to say that I am very dissatisfied with the sound quality in my '09 MCS with the base sound system. It is not clear and the base has no power behind it. I think I read on here that Fade function was programmed wrong so they had to reverse the signals to the front and rear speakers. If that is the case, I would like to un-reverse it even if it means the Fade function will work in reverse. Has anyone else tried this?
So it sounds better but also costs quite a bit more than anything offered by MINI.
POlk speaker upgrade
On the topic of aftermarket for audio on the newer MINIs, is it a fairly standard affair when showing the stock car setup to a high quality audio company or do they sctatch their heads at the MINI setup? Guessing that someplace like a Best Buy is out of the question for doing any aftermarket installs/upgrades? Would be curious to hear what kind of luck folks have had going to a specialty shop.
