R50/53 Trying to Remove Starter for testing !@%$
Old Jul 7, 2011 | 01:57 PM
Heady's Avatar
Heady
Any suggestions, cannot remove the golden colored bolt on bottom of the starter.
Feedback from those who've done this is appreciated
Old Jul 7, 2011 | 03:25 PM
Blackbomber's Avatar
Blackbomber
Is the bolt not turning, or are you having issues getting to it?
Old Jul 7, 2011 | 04:56 PM
Heady's Avatar
Heady
its not turning
Getting to it, although its a pain.
Old Jul 7, 2011 | 05:12 PM
Blackbomber
I actually did mine with the engine out of the car (story for another day), so I'm really not 100%. I can tell you according to the Bentley, you are supposed to remove the exhaust manifold, and do it from the top. Personally I might try to do it from the bottom, but as tight as it is down there, it might actually be less work to pull the manifold and do it that way.
Old Jul 7, 2011 | 05:30 PM
Heady's Avatar
Heady
I've done both, and still cannot get it to turn. It's not a reverse direction bolt is it?
Old Jul 8, 2011 | 07:23 AM
Blackbomber
No, it's standard thread. Every bell housing bolt, as well as the starter mounting bolts, is the same (length, diameter, thread pitch, etc). My experience was with a manual trans, but the Bentley didn't specify, so I presume it's the same.
It's not very helpful, but I've included a pic of my new starter, with the heat shield and wiring removed. It's an R53 starter and trans, but the mounting is identical.
Attached Thumbnails Trying to Remove Starter for testing !@%$-219345_1830841889035_1180016528_31854662_5055680_o.jpg
Old Jul 8, 2011 | 07:29 AM
Heady's Avatar
Heady
thanks
By chance do you remember the wiring? There us a larger threaded lead and a small threaded lead. There are two larger gauge wires that I out on the larger threaded post which is closest to the fire wall and wanted to make sure its correct.
Old Jul 8, 2011 | 08:02 AM
Blackbomber
I've attached another photo, of how the car was wired prior to removing the original starter. As you can see, there are two lugged leads connected to the larger threaded post on the solenoid, and one smaller, attached to the smaller post, which is not really visible in that shot. The small one is in the wrapped harness, and the larger ones are in plastic split loom. I think the second larger one that runs towards the passenger side might go to the EPS motor, but I'm not 100%
Attached Thumbnails Trying to Remove Starter for testing !@%$-172648_1713876924984_1180016528_31699664_7213950_o.jpg
Kimolaoha
Jul 5, 2023 01:04 PM
09R56
Nov 16, 2022 10:49 AM
Helix13mini
Oct 26, 2018 05:50 PM
greekzilla
Aug 23, 2015 03:44 PM
rckrzy1
Aug 11, 2015 06:06 PM
