Suspension Front Sway Bar And Bushings
Old Jun 11, 2011 | 02:13 AM
Marwan's Avatar
Marwan
Hey there!
My question goes to suspension gurus . I'm going to change the front control arm and front sway bar bushings to Powerflex Polyurethans on my R53.
Since I'm going to take the subframe down, I'm thinking of havin a new front sway bar, so:
-Which front sway bar do you recommend?
-What other bushings do you recommend to change for longer life and less headache? I'm so f**king tired of the OEM short life bushings.
Thanks in advance for reading and chiming in!
Old Jun 11, 2011 | 07:32 PM
90STX's Avatar
90STX
I went with the 27mm H-Sport front sway bar, set to the softest setting. I have the H-Sport 25mm hollow rear bar, set on the stiffest setting.
My goal in making the change was to be able to run softer damping levels for bump compliance on course without giving up to much roll control. This was for autocrossing, and worked as intended.
As for bushings, I've replaced them all with poly.
Scott
90SM
Old Jul 2, 2011 | 09:38 PM
ATXZJ's Avatar
ATXZJ
I kept, and recommend keeping the stock bar with the addition of powerflex bushings. The LCA bushings were a PITA but totally worth it. Lastly, an 18mm flexhead ratchet wrench is your best friend
Old Jul 4, 2011 | 08:43 AM
drftobin's Avatar
drftobin
I just did powerflex for the control arm bushings and sway bar bushings good improvement over stock, and kept the stock bar!
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
minipopkart
Aug 13, 2015 05:22 AM
