Name that noise
Old Jun 5, 2011 | 05:45 PM
hexon's Avatar
hexon
Name that noise
I've had my 04 Mini Cooper (Justa) for about a month now and it's been making a whirling sounds when I let off the acceleration and coast. If I step on the gas or push the clutch in the sounds goes away. It's not an extremely loud or annoying sounds. It just sounds like a remote control RC car almost. One could even describe it as a "puttering" sound maybe. It's almost as audible as the humming of the car as I gear down when engine breaking. It is coming from the driver's side front area. Any ideas? I thought it was just a normal noise until my brother, who has more experience driving a manual, commented on it. And I want to make sure something isn't messing up.
Old Jun 6, 2011 | 01:31 PM
hexon's Avatar
hexon
Ok I payed particularly close attention today when I drove. The sound doesn't occur in 5th gear at all that I've noticed. I'm not in 1st gear long enough to notice it, but the other gears all have this sound. I said previously that you couldn't hear it when you press the gas, but that isn't fully true. Instead hitting the gas only masks the sound a bit; however, a light tap of the gas will make the car almost silent.The sound is very rhythmic and repetitively, almost like turning on and off an electric razer very quickly. If I turn up the radio a bit I can't hear it, though. Is this just the sound of the engine/tranny? Sorry, I'm a mini newbie.
Old Jun 8, 2011 | 12:05 PM
Burno's Avatar
Burno
Kind of hard to tell by the description , could be a number of little things or 1 major issue.. 5th gear might not have that heavy a load on bad gears ...and only under acceleration stress you hear bad gears. Or throw out bearing is going , maybe a bad crank pully ,but that wouldnt explain the push in clutch and it goes away part........pressure plate might be damaged though.......not exactly sure......
Old Jun 8, 2011 | 08:16 PM
hexon's Avatar
hexon
What would you say a bad gear sounds like?
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Miniwaukee
Sep 29, 2015 09:22 AM
