Speed Sensor related to recent pulley install?
Old Jun 1, 2011 | 11:57 AM
stt816's Avatar
stt816
i just got my pulley installed about 2 weeks ago and just yesterday i got the dsc. flat tire, abs lights on. I know its the wheel speed sensor but do you think it has to do with them installing the pulley? maybe they didnt connect it back up or something...
Old Jun 1, 2011 | 12:37 PM
Eric_Rowland's Avatar
Eric_Rowland
Wheel speed sensor isn't touched during a pulley install. If it was disconnected (or inadvertently broken, the lights would have come on immediately.
Old Jun 1, 2011 | 01:18 PM
HRM's Avatar
HRM
Plus two weeks went by...They are unrelated.
Old Jun 1, 2011 | 03:05 PM
Flyingfrenchman's Avatar
Flyingfrenchman
I'm assuming you checked tire pressure?
Old Jun 1, 2011 | 08:41 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
It is possible if you mechanic unclipped the rt front wheel speed sensor from the holder that is right next to the bolt for the pass motor mount the wire can hang loose and rub on the crank pulley causing your light. We have MINI's all the time come in that "Just had ..... done and now the ABS light is on?" and we have found this wire rubbing.
Otherwise normally the ABS light and a pulley are not related.
Sexual Chocolate
Mar 31, 2019 08:02 PM
maestro39
Oct 27, 2015 02:38 PM
squawSkiBum
Oct 2, 2015 09:21 AM
iamcamkeenan
Aug 10, 2015 03:31 PM
