Creaky clutch pedal or cable or something?
Old May 31, 2011 | 06:29 AM
ericscottf's Avatar
ericscottf
Hi all
Mini convertible (no s) Sept 2004 delivery, 2005 model year, 5 speed manual.
52k miles, most of them local (so a higher than average amount of clutch use)
parked next to a wall today with the window down and I noticed a sort of a creaking noise when I depress and release the clutch, in gear or out. The noise may have been there for awhile now, but i didn't notice it until i was next to something for the sound to bounce off of. Not too loud, but i want to get ahead of any serious problems.
It sounds like the noise you might imagine from a rusty spring or wire going over a pulley or a dry hinge. a low volume short mechanical creak. I'm guessing it's a cable or pulley associated with one of the clutch pedal components.
I'm hoping this is a common, easily diagnosed issue and someone here can let me know if it's a big deal or not, where to look, and what the probability is that it is what they're suggesting.
thanks
Eric
Old May 31, 2011 | 10:20 AM
Mini for life!'s Avatar
Mini for life!
Old May 31, 2011 | 10:21 AM
ericscottf's Avatar
ericscottf
oh, of course, that explains it. i'll hit the consession stand immediately for butter.
Anything else i should look into?
Old May 31, 2011 | 10:28 AM
Mini for life!
i have the same problem i just subscribed. i need to find out what is making this creaky sound in my car too
Old May 31, 2011 | 10:29 AM
ericscottf's Avatar
ericscottf
Aha. Anyone replying, please keep in mind that we have different trannies.
How long ago did you notice yours?
thanks
Eric
Old May 31, 2011 | 11:19 AM
JAB 67's Avatar
JAB 67
Most likely the throw-out bearing. Poor design. Newer versions are reportedly better.
Old May 31, 2011 | 11:42 AM
daflake's Avatar
daflake
My vote is on the linkage being gunked up. This happened on my 06 S and we pulled the airbox, cleaned and re-lubed the linkage to solve the creaking issue. I would be willing to bet it is the same on the cooper.
Old May 31, 2011 | 11:44 AM
ericscottf's Avatar
ericscottf
Just got an email from the dealer:
The clutch assembly uses plastic parts that can sometime cauase that noise. Usually we just lube it and its fine but I would like to still inspect it to make sure there aren't any faulty parts. Would you like me to set up an appointment?
I asked her to give me a ball park location for these components so i could check them first. Will post if i get anything useful back.
Old May 31, 2011 | 02:27 PM
Mini for life!
my throw out bearing is bad i get that clack clack clack sound when is neutral but i get that creaking sound when i engage and disengage the clutch
Old Jun 1, 2011 | 08:32 AM
ericscottf's Avatar
ericscottf
I noticed the sound wasn't there yesterday when i started my drive.
so it seems to be intermittent.
Does this provide any clues?
Old Jun 1, 2011 | 12:30 PM
FlzRider's Avatar
FlzRider
https://www.northamericanmotoring.co...-warms-up.html
thadscottmoore
Sep 25, 2015 10:07 AM
BadgeFTW
15
Sep 20, 2015 11:39 AM
Sep 16, 2015 06:22 AM
Sep 16, 2015 06:18 AM
wildwestrider
Sep 4, 2015 06:25 AM
