Turn Signal Turns High Beam On Each Time I Signal for a Turn
Old May 30, 2011 | 09:19 AM
gob15's Avatar
gob15
Hey all,
In the past month I have been having a problem with my turn signal. Each time I signal left or right my high-beams go on. I am unintentionally flashing the cars in front of me. The signal itself seems to me a little floppy and it must be making the contact connection for the high-beams.
Is there a tweak I can make to adjust the signal so it does not continue to make the contact for the high beams or will I have to replace the actual signal mechanism?
This is a 2004 MC
Thanks!
Old May 30, 2011 | 11:16 AM
MC2005s's Avatar
MC2005s
same thing happened to me when I bought mine. just have to make sure you are pushing straight down and not moving it towards you at all. 6 mos. later seemed to work for me.
Old May 30, 2011 | 12:08 PM
gob15's Avatar
gob15
That worked for a while but the actually lever is loose. A light tap forward on it will turn the high beams on. Sometimes a bump in the road will move the lever enough to turn them on.
Googling and doing more searches on this forum come up with other names for this piece...lever, stalk, wiper/turn switch. So I imagine it will not be fun trying to hunt this part down
Old May 30, 2011 | 01:51 PM
rkw's Avatar
rkw
$137.88
Should be no problem at all. Switch, stalk, lever -- everybody will know what you're talking about if you say it's for the turn signal.
Anyway, it's part #61311484333 if your car has the on-board computer (push button on top of the ****) or #61311484331 without the button. RealOEM says the list price for a new part is $137.88. A used part from an auto recycler will be much cheaper.
http://www.realoem.com/bmw/showparts...02&hg=61&fg=35
Replacement isn't difficult. The trim plastic above and below the steering column need to be removed but not the steering wheel itself. The switch is attached with one screw.
Old May 31, 2011 | 08:42 AM
gob15's Avatar
gob15
Thanks. This is very helpful info. I appreciate you taking the time going in to detail. I guess at this point I just need to to determine whether it does need a replacement or if it is something I can fix myself.
Thanks again!
Old May 31, 2011 | 01:16 PM
HRM's Avatar
HRM
I have seen them in the marketplace here. This is a good candidate for a used part in my mind. Either it works or it doesn't, though yours seems to have worn out. If it is cheap enough especially if it is easy to replace, used may be a good option. If the money difference isn't big, or it is a hard job, I would just pay the man.
Old Feb 28, 2013 | 10:46 AM
lizandrooo's Avatar
lizandrooo
I have the same problem! I took mine apart and it looks like theres a worn out plastic bump :/ Im trying to see if I can stuff a landline telephone clip or something! Anyone got any ideas with this ?
Old Oct 18, 2013 | 01:08 PM
R1150GSA's Avatar
R1150GSA
I had the same problem as the OP. Took the turn signal assembly off, pried it open, and poked around a bit.
I assumed the spring was worn so I stretched it a bit. Putting the whole mess back together was a real logic puzzle. Once everything was back in place I popped it back into the steering stalk. Fired the car up and checked the turn signals. Working fine now, but don't have high beams anymore. That's good news for the folks that were getting flared every time I would signal right-hand turns. Bad news for me because the deer rut is going on right now and I could use the extra light throw at night.
I ordered a new assembly from Mini Cooper Parts Giant online. Total cost (with 2-day shipping) $147.78.
The parts guy said that the northeast distributor for parts just went bankrupt. BMW, Mercedes, and a bunch of others are scrambling to find alternate shipping sources.
Long story short, I'm stuck with low beams until at least Tuesday next week. Could be worse, I suppose.
Old Aug 2, 2015 | 02:36 PM
cristo's Avatar
cristo
Alliance Member
My high beam has been coming on intermittently when using the turn signal
for several months now. Finally ordered the part (about $80 with shipping).
It looks like a very easy install.
Old Oct 3, 2015 | 09:10 AM
yinyang2coops's Avatar
yinyang2coops
Mine started yesterday plus high beam sticks on unless click it a couple of times or turn headlights off then back on - called the dealer today in case they had them in stock. Not in stock but are on sale with no shipping charge - $82. Will be here in 2 days. Flow Mini in Raleigh, NC
Old Oct 4, 2015 | 05:15 AM
cristo's Avatar
cristo
Alliance Member
I replaced it a month or so ago. About the same price as you mentioned.
It was an easy install except one of the screw threads that holds the lower
steering cover trim up was toast (probably from when the dealer put my alarm
in at time of purchase in 2003!), and I used a slightly larger sheet metal screw
instead of the machine screw to hold it back in.
Old Oct 4, 2015 | 05:48 AM
buzzsaw's Avatar
buzzsaw
Whenever a screw will not tighten in other than a wood product, I take a small bit of fine steel wool and pack into the the hole and reinstall the screw. Works every time. Did that recently on the left screw that holds down the JCW CAI box and the rear license plate holder. FWIW.
Old Oct 12, 2018 | 07:58 PM
Tombstone's Avatar
Tombstone
error
Old Oct 14, 2018 | 02:30 AM
Tgriffithjr's Avatar
Tgriffithjr
The answer to this problem is simple. Don’t use your high beams. Actually don’t use your turn signals either; no one else does anyway. If you don’t use it; it can’t break.
09R56
Nov 16, 2022 10:49 AM
Teh
Jun 13, 2018 02:59 PM
Dec 23, 2015 10:36 AM
kpl
Aug 11, 2015 04:52 AM
