Hatch panel (not boot) full of water after hard rain!
Old May 26, 2011 | 05:38 AM
toxictv's Avatar
toxictv
Howdy folks! 2004 MCS.
Any time I open the hatch after a hard rain, if I let it open more than half-way water runs out from the edges of the inside panel of the boot (the one with the big round hump in the center) and all over the boot! There's a little moisture in the battery area, but the carpet is never soaked until I open the hatch and leave it open.
Also, it seems there is a bunch of dirt/dust behind that panel, as it always runs out and fills up the seals surrounding the hatch.
What seals do I need to look at? I'm leaning toward the seal on the outer part that sits between the bottom of the glass and the body panel, just above the handle. I've noticed some people mention the actual handle, and the third break light. I'd like to get a decent list then do everything preventative I can for them all at once.
Thanks guys =D
Old May 26, 2011 | 06:26 AM
Vollgas's Avatar
Vollgas
The 3rd brake light seal is probally the one leaking.
They have a tendency to do that.
Old May 26, 2011 | 06:32 AM
toxictv's Avatar
toxictv
I'll check it out. Any trick to getting it loose?
Old May 26, 2011 | 07:14 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes the 3rd brake light commonly has the seal leak, or gets cracks in the lens that leak. If it isn't leaking I have seen the seal on the grip strip where the hatch button and license plate lights are leak.
Old May 26, 2011 | 07:24 PM
toxictv's Avatar
toxictv
...hmm. BRB, going out to my driveway.
...back. Well, no apparent cracks. But, someone did install the big boot spoiler at one point, and it has big gouges on either side like they backed in to something low (*******es.) So it's possible that's leaking, as well.
What's involved in taking off that boot panel to get to the spoiler and 3rd brake light?
BTW, this is Daniel Champion, the fellow with the broken back in Arkansas that has your lower control arm bushing cores
woodstudio
Mar 15, 2020 08:28 AM
WarEagle
R55 :: Clubman Talk (2008+)
May 3, 2019 03:00 AM
actualsize37
Sep 1, 2015 06:43 AM
