R50/53 Another Sun Roof leak
Old May 24, 2011 | 08:46 PM
Tylermtech's Avatar
Tylermtech
So my new to me MINI has a pretty good sunroof leak. After a good rain, I noticed a ton of water in the foot well. So.. I followed the instructions on the internet, and found out that my front drain was disconnected. I hooked it up and put on a hose clamp and I am still getting water in the foot well when I pour water in the sunroof drain. I did this with it taken apart and cant see water leaking between the drain and the metal tube. It also seems to be draining out the front pretty well.
I also tried dumping the water down the back of the track, and it all seems to drain out the rear outlet.
Also, after I took it apart, the thermometer reads -13 deg f?
what have I done!!
Tyler
Old May 24, 2011 | 09:20 PM
Filmy's Avatar
Filmy
Have you tried disconnecting the rubber tubes from the metal tubes and running something like weedeater line down them? They may just be clogged.
Old May 25, 2011 | 09:06 AM
Tylermtech's Avatar
Tylermtech
I will try that, but I'm pretty sure they are clear as most of the water drains out through the drain holes when i dump water in them.
gmonde
Sep 8, 2015 06:37 AM
jziran
Aug 24, 2015 04:50 PM
Aug 12, 2015 01:24 PM
