Tire Pressure
Old May 21, 2011 | 07:04 PM
or birdman's Avatar
or birdman
Tire Pressure
For Autocrossing with my 78 mini how much tire pressure should I run. I have 165/10 Yokohama AO32s
Old May 25, 2011 | 01:14 PM
Alex@tirerack's Avatar
Alex@tirerack
That's a tricky one, Your car is SO light, I'd guess 34-36 lb range and adjust with a pyrometer's (probe style not IR) help.
These newer cars use much higher pressures, but they have more mass to deal with. It also helps to have a friend that can take the tire probe temperatures - you'll be loosing heat pretty quickly.
I think you'll also want to make the adjustments based on sidewall flex - I am thinking lower pressures to aid in the build up of heat.
Alex
Old May 26, 2011 | 02:12 AM
or birdman's Avatar
or birdman
Originally Posted by Alex@tirerack
T
Alex
That's what I did. Put shoe polish on the tires so I could see where it wore off. Ended up at 21 lbs pressure.
Old May 26, 2011 | 03:02 AM
cmt52663's Avatar
cmt52663
A friend with an adult kart is in the 11-14 lb range. Of course the kart weighs more, and has larger wheels...
khumpert
Nov 30, 2015 11:48 AM
oldkid6
Aug 30, 2015 08:28 AM
TJANK
Aug 24, 2015 06:11 PM
nomar116
Aug 9, 2015 09:42 AM
