1st Gen JCW Suspension R53 And GP
Old May 17, 2011 | 08:28 AM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Anyone else find that their JCW Sport Suspension has dropped more than inch since the initial drop of the advertised of 10mm since installation ?
Old May 17, 2011 | 09:41 AM
quikmni's Avatar
quikmni
The JCW suspension on my GP is about the same height as originally with 66,500 miles. I did replace the front top strut mounts with adjustable camber plates.
Has the front, rear, or both ends dropped? If just the front, you might want to inspect the rubber top strut mounts to make sure they are not ripping/tearing.
Old May 17, 2011 | 10:06 AM
-=gRaY rAvEn=-
Moderator
Both front and rear have dropped over an inch equally....sorta perplexing.
The mounts are original. The set up has also lost some of it's stiffness in the corners and over bumps it feels more like a R53 sport suspension, bit less forging and more harshness.
JCW springs were just replaced hoping that was the cure, but after a very short period has dropped back to over 1" drop.
Old May 17, 2011 | 10:36 AM
quikmni's Avatar
quikmni
I remember when the shocks were starting to wear-out on my 03 MCS, the shocks seemed to get stiffer (added harshness) but that still does not explain your suspension drop.
Old May 17, 2011 | 10:46 AM
-=gRaY rAvEn=-
Moderator
Yeah that is my quandry.
As far as I know, these springs are made by Eibach....and their springs have about as much drop as I have now....
And we initially thought the springs would have more to do with the ride height. But since these are gas pressurized struts ( Bilsteins ) was wondering if maybe the pressure in the struts actually bring the cars ride height up some.
This can be seen after a MINI has been up on a lift in the shop. Then takes a bit for the valving and gas pressures to settle into normal ride height.
Only in my case, they are settling a bit too much. Had to shave off the bottom of my Aero bumper lip this summer......
Old May 17, 2011 | 01:12 PM
HRM's Avatar
HRM
When I put the FSDs in my car, keeping the sport springs, the car sits higher. I did add IE fixed plates, but to me, the height seems higher than just that. I never thought of shocks as having an effect on ride height, but I'm not so sure now.
I guess what I am saying is maybe the shocks have something to do with it.
Old May 17, 2011 | 02:21 PM
quikmni's Avatar
quikmni
You are right about how the car does not return to a normal ride height after being jacked up and then lowered back down. I never really thought about it much but it does take some shock cycles to get the car back down to a normal level so there probably is some validity to the shocks actually holding up the car a little (which should be the job of the springs). You might be on the right track with the thought that the shocks have lost some pressure and let the car sink a little.
Old May 17, 2011 | 07:10 PM
-=gRaY rAvEn=-
Moderator
This is what I have found so far but would love to confirm here:
" Gas struts add ride height, the force that is trying to extend the strut is inside the spring but not contained by it. So the spring works on the same structure as the strut. If the strut is charged, it essentially adds to the spring rate. If it is not, then it doesn't....."
"In my experience, fresh gas charged inserts will raise the ride height by 10-15mm over non-gas, or gas-charged inserts that have lost their charge...."
Forum here on gas charged struts
Old May 18, 2011 | 05:01 AM
THE ITCH's Avatar
THE ITCH
gRay rAvEn
My GP also is the same height as original. I only have 19,000 miles on it and in the winter it is off the road and up on jack stands with the wheels removed to relieve the weight from the suspension.
Just a quick question. Are you sure that the JCW struts and shocks are made by Bilstein?
Thanks, Steve
[quote=-=gRay rAvEn=-;3286356]Yeah that is my quandry.
Old May 18, 2011 | 11:35 AM
-=gRaY rAvEn=-
Moderator
Thanks Guys
Yeah when MINI came out with the kit, they advertised it as having the springs specially made by Eibach and struts by Bilstein....but who knows.
At this point I guess I should be looking into adjustable CO's.
Emnotek
Aug 13, 2015 05:47 PM
Minibeagle
Aug 13, 2015 10:00 AM
xpunisherx
Aug 10, 2015 10:50 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
