Suspension TSW or H&R Springs for lowering and handling?
Old May 10, 2011 | 08:12 PM
dannyhavok's Avatar
dannyhavok
Hey guys, I browsed through a few old threads but I'd love some more input. Thinking about my future mods, and I know I'm going to need some springs.
I would really like to get rid of some of the wheel gap. I would also like to stiffen up the ride a little to reduce body roll. I get the impression that TSW from Way are the favorite for handling, but don't lower much. The H&R from Alta seem to offer a nice drop but I can't find a lot of feedback on handling.
Can anyone offer insight on this? Experience with either, both, or something else?
Old May 10, 2011 | 08:33 PM
rohicks's Avatar
rohicks
In my experience in lowering vehicles (have not lowered a mini) you'll either want a full coilover set or get some solid struts (like adjustable KONIs - what I had on my last vehicle) to run aftermarket springs on. Either that or your stock struts will take a **** soon enough.
Old May 11, 2011 | 01:05 PM
quikmni's Avatar
quikmni
On my 03 MCS I had H&R springs for 45,000 miles with the stock shocks. But the shorter springs will wear out the shock shocks a little faster.
I found the H&R springs to be good for looks and performance. I used my car as a daily driver and tracked the car three times with the H&R springs. I like the lower drop of the H&R springs better than the TSW springs.
However, from what I have read the TSW springs are very good. I have not used the TSW springs but currently have JCW springs which I suspect are very close to the TSW springs. My JCW springs are great.
I would go with the H&R springs due to the little lower drop.
Old May 11, 2011 | 07:47 PM
dannyhavok's Avatar
dannyhavok
Thanks for the input! I figure I will need to replace the shocks at some point anyway, so a little increased wear is no big deal. I don't put a lot of miles on the car anyway, my commute is short.
Old May 12, 2011 | 07:03 PM
andyroo's Avatar
andyroo
IMO the more mild the drop, the better the handling and ride quality for the Mini. There just isn't any bump travel to work with so the less lowering the better. My roads are terrible but the bump travel is still good for handling on smooth roads.
I really like my Konis and Tein H-tech (not s-tech, those suck). The drop is really minor, maybe 10mm with IE Fixed camber plates. The TSW's are supposed to be very good too.
Old May 15, 2011 | 11:37 AM
wrh3's Avatar
wrh3
Have you looked at Apex springs? http://apexsuspension.com//gb/index.php
I think the only US distributor I have seen them at is Moss:
http://www.mossmini.com/Shop/ViewPro...eIndexID=94666
They are linear and work well with Bilstein Sports (although they worked OK with OE dampers the Bilstein allow for a bit more travel)
I don't hear a lot about these springs on the forum and was kind of skeptical when I bought them as a stop-gap while saving for coilovers. I was so pleased I decided not to do coilovers but upgrade the dampers. They handle great, look great, and are really a great value.
Old May 15, 2011 | 11:44 AM
Albiecrazy's Avatar
Albiecrazy
I've got the H&R's along with ALTA's 19mm rear sway bar on my R56. I like that it's dropped lower than the TSW's and as a daily driver, I'm having no issues at all.
It's that rear sway bar that will take away some body roll - I really couldn't believe how tight the car was after it was installed. But you already know that!
Old May 15, 2011 | 11:37 PM
nopistons's Avatar
nopistons
According to Apex, only the rear are linear. The front are progressive
Front: 25-20001/1VA = 28 N/mm -> Progressive spring type
Rear: 25-20002HA = 36 N/mm -> Linear spring type
Old May 16, 2011 | 04:28 AM
Act_04's Avatar
Act_04
I have the Megan Racing coilovers, so no experience with the springs mentioned. That being said I do know that Swift is making, or has finished making lowering springs for the Mini. I have heard nothing but rave reviews about Swift. They have a facebook page in addition to their website.
Old May 16, 2011 | 04:42 AM
wrh3's Avatar
wrh3
Maybe they are taking into account the progressive bumper? The front spring looks linear:
W0TM8
Dec 19, 2019 07:50 AM
melscoop
Mar 30, 2016 06:56 PM
loop4re7
Oct 5, 2015 09:53 PM
G1HQ
Aug 28, 2015 01:41 PM
Emnotek
Aug 13, 2015 05:47 PM
