Suspension Rear Shock Travel Measrurement
Old May 7, 2011 | 03:02 PM
bluefox280's Avatar
bluefox280
For those who removed your R55 / R56 / R57 OEM suspension, could you pull a measurement?
I'm looking for the rear shock piston travel.
To determine, compress the shock fully and mark the line on the piston shaft next to the shock sleave.
Then expand the shock to it's fully topped-out; then with a tape measure, measure the line you marked to the shock sleave.
If you could be within a 1/16" accuracy it would be greatly appreciated.
Also, denote what platform you have along if you know its the regular or 'sport' suspension option from factory.
- Erik
Old May 7, 2011 | 04:37 PM
etalj's Avatar
etalj
- Erik
I can do that for you. Just give me a little while
Old May 10, 2011 | 11:29 AM
bluefox280's Avatar
bluefox280
Gotcha; what's the ETA you think?
- Erik
Old May 17, 2011 | 03:21 PM
bluefox280's Avatar
bluefox280
Bumping this; just need 5 minutes of time from anyone who has the OEM rear struts removed from their vehicle.
- Erik
Old May 18, 2011 | 07:22 AM
JamesL_71's Avatar
JamesL_71
I have a set of OTS Koni Sports off the car right now. From what I have read, the dimensions of the rear Koni are identical to the OEM dampers... however, I do not know if that is 100% true.
I already have all the dimensions of the front and rear Konis recorded; body/shaft diameter, body/shaft length, stroke, compressed/extended lengths, etc, etc, etc. The info is at home (@ work currently), if it would be of any help to you just let me know.
Old Jun 2, 2011 | 09:29 PM
bluefox280's Avatar
bluefox280
James, appreciate it; however, still looking for OEM data first.
Seems like you and I are in the same boat according to your motion ratio thread...
- Erik
Old Jun 3, 2011 | 12:10 PM
andyroo's Avatar
andyroo
I have OEM R53 rears off the car at home. Probably the same as R56, but don't know for sure. I do not have the bumpstops though in case you wanted their length too.
James, you should post the info when you get a chance. A thread with measurements on bump travel at normal ride height, with and without the bumpstops would be valuable as well as the true motion ratio data.
- andrew
Old Jun 5, 2011 | 02:22 AM
etalj's Avatar
etalj
oh, I'm so sorry, I forgot about this completely. I'll have the answer for you in around 24 hrs, when I get back home.
Sorry again.
Old Jun 6, 2011 | 07:21 AM
etalj's Avatar
etalj
It's 125mm. Stock sport suspension off my JCW. If you need it to be highly accurate, I'll get back to you tomorrow?
Old Jun 6, 2011 | 08:43 AM
bluefox280's Avatar
bluefox280
For clarification, that's the full stroke of the rear shock without a bump stop? Thanks!
- Erik
Old Jun 6, 2011 | 08:50 AM
etalj's Avatar
etalj
- Erik
Correct No bumpstop.
My pleasure
Old Jun 6, 2011 | 04:15 PM
JamesL_71's Avatar
JamesL_71
I measured 4.675" of stroke on my standard Koni Sports... or ~120mm from fully extended to collapsed.
Old Jun 6, 2011 | 04:48 PM
cmt52663's Avatar
cmt52663
my rear shock travel to date is 159,988.208843 miles.
approximately.
kind regards,
Charlie
(bear with me, I seem to be in an odd mood this evening - but the Bilsteins that accompanied the H&R coil-overs are indeed remarkably durable)
woodstudio
Mar 15, 2020 08:28 AM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Toolman
Jan 20, 2016 06:50 AM
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Emnotek
Aug 13, 2015 05:47 PM
