Suspension Replacing shocks what else should I replace
Old May 5, 2011 | 04:38 PM
hawkinsmc's Avatar
hawkinsmc
My 02 MCS has 130,000 miles on it, the ride is pretty harsh and I took it in the other day and they said I have leaks on 2 of the shocks. So I am replacing my Shocks and struts with Koni FSD (I am hoping for a much smoother ride)
Anyway, is there any bushings or mounts that I should replace while I am replacing the suspension. I do have a minor knocking sound up front at times and it seems like I read somewhere that this is a common prob and some bushing needs to be replaced. Thanks for the help.
Old May 5, 2011 | 05:29 PM
HRM's Avatar
HRM
Yes, I wish I had gotten a new pair of the strut bellows for the shocks.
Old May 5, 2011 | 05:31 PM
JAB 67's Avatar
JAB 67
Front lower control arm bushings.
Old May 5, 2011 | 06:01 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
In addition to the CAB's ( Maybe Powerflex brand ? ) I would also consider new set of OEM spring pads for the front and the "additional shock absorber" pads for the rear, then have an alignment done by the dealer. Many alignment shops out there either are unable to properly do one, fake it, or give MINI owners the bums rush stating they can't/don't want to do it....
If you are swapping out the suspension components yourself, it would also be a good time to clean up and paint the front/rear calipers...... if so inclined.
Old May 5, 2011 | 06:41 PM
JAB 67's Avatar
JAB 67
Gray Raven: Could you please elaborate on what you are describing?
Old May 5, 2011 | 06:47 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With that kind of mileage a set of powerflex control arm bushings and front sway bar bushings would be best to replace.
Old May 6, 2011 | 05:43 AM
NH_MCS's Avatar
NH_MCS
Also add the inner and outer ball joints to the list.
Old May 8, 2011 | 04:03 AM
-=gRaY rAvEn=-
Moderator
CAB= Control Arm Bushings- I run powerflex purple. They make yellow, purple and black. Black are the hardest but give some NVH. ( Noise Vibration / Harshness to the ride )
My sway bar busings are also Powerflex purple, but next time I may go black. Huge gains there as the stock front bars are perfect for our cars so these really help an already great front bar thickness.
The other parts for the struts are only available from MINI. If you call them and just tell them what I wrote, they will know. Two months ago I contacted Powerflex of the UK about these same parts to see if they would/could make them. They were not interested...
Old May 8, 2011 | 11:05 AM
quikmni's Avatar
quikmni
Also check the top strut bushing/mount (can see from the engine compartment). The rubber tends to crack/tear. If it needs replacement, I would suggest the IE Fixed Camber Plates because they are stronger than the OEM mounts.
http://www.waymotorworks.com/ireland...e-r50-r53.html
DixonL2
Apr 13, 2021 08:05 AM
eliseo1981
Jan 28, 2021 02:45 PM
woodstudio
Mar 15, 2020 08:28 AM
Emnotek
Aug 13, 2015 05:47 PM
nomar116
Aug 10, 2015 11:24 PM
