Suspension How Adj. Koni Yellows on R56?
Old May 4, 2011 | 03:10 PM
Dwight Walhood's Avatar
Dwight Walhood
Got a set of Koni Sport/Yellows on the way and not at all sure how you adjust the rears once installed. Looked real close and all I could find for access to the adjustment **** is a suspicious looking plastic cover where the rear seat backs lock into place. Is that it? It seems to be in the right place.
Old May 4, 2011 | 04:56 PM
Vollgas's Avatar
Vollgas
You can not adjust Koni's once they have been installed.
Recommend 2 clicks from hard setting.
Fronts, 2 clicks from softest.
Old May 4, 2011 | 07:38 PM
Dwight Walhood
Per NM tech: the Koni Sport adjustable front struts are easily adjustable on the car. The rear shocks must be removed to adjust. Mine will be staying on the softest setting to start with.
Old May 4, 2011 | 10:48 PM
rohicks's Avatar
rohicks
I don't know how they are on the minis.
I had the adjustable KONI's on my neon r/t and they came with an adjustable **** that I could slide on to the top of the strut and turn to soft/hard or in between.
I would assume they should be the same or similar, but it appears not from the conversations above.
Old May 5, 2011 | 04:15 AM
slinger688's Avatar
slinger688
Option 1: Take off the rear shocks from the top mount and adjust them from the top
Option 2, Cut a hole into the top wheel well plastic from the trunk and get to it from there
This is why I decided against Koni yellows on my car since I adjust these often enough.
Old May 5, 2011 | 08:45 AM
andyroo's Avatar
andyroo
I set my R53 Konis at 1/2 turn from full soft and I'm happy with them. That would work well for stock or most lowering springs, maybe a hair firmer for an R56.
- andrew
battlehawk_mini
Mar 5, 2021 06:15 AM
rtk90
Aug 29, 2019 09:08 AM
elightbo
Tires, Wheels, & Brakes
Sep 2, 2015 08:17 AM
