R50/53 Ok, I think I give up :)
Old May 3, 2011 | 05:35 PM
mini53's Avatar
mini53
After only 5 months, I think I give up on my 2002 R53 Cooper S with Full Aero Kit.
I know I am not getting my money back, but I figure it is worth a little more than I originally purchased it for. I don't have the time for the little things on the car and just need to be able to get to work with it.
Compression/ Leak down test done on all 4 and is as good as stock/new on 134k Motor
What do you guys think it is worth? With the knowledge that mechanically it is 99.9%
All work was done at Greasy's Garage.
What it has:
Alta Intake
Alta Short Shift
Alta Reduction Pulley
Borla Exhaust
Adjustable Rear Links for trailing arms
Aux input
Sirius Radio
Newer Stock MP3 Radio
3rd Party Clutch
Front Strut Bar
Radiator Replaced
Sunroof
3 Spoke Steering wheel/airbag upgrade
Done in the Last 4 Months $4k of work:
4 New Tires
New JCW Suspension and Springs
Powerflex Poly bushings w/Alignment
Lightened Crank Shaft
New Fogs
New Front Corner Lights
New Rear 3rd light
Thermostat
Engine Fan Assembly
PowerSteering Pump
PowerSteering Fan
PowerSteering Fan Gaurd
25.5 MM H-Sport Rear sway bar
New Oil Filter Housing (was cracked)
Crack before CAT welded (Common Issue)
Water Pump Replaced
Super Charger Removed, cleaned, inspected and oil replaced, found to be not the original.
Windshield
Hella Horns
Coolant Reservoir
All Coolant Hoses
DSC Defeat/Auto Up windows, etc mod.
BMW Peabody Dealer Work for Oil Leaks $2k of work:
Valve Cover Seal
Oil Pan
Crank Sensor Seal
I have all receipts for work done for Greasy's as well as Work done from Dealer.
I am sure I missed some small things.
Greasy's is 1 year parts and labor warranty
BMW is 2 years I believe.
Old May 3, 2011 | 05:43 PM
Evasive's Avatar
Evasive
Personally, I wouldn't get rid of it. You've put so much into it already and I doubt you'll get much more than what you paid for even though you've put a lot into it.
Old May 3, 2011 | 06:15 PM
mini53's Avatar
mini53
Thanks, I got the car for 6k, thinking I would put 3k into it, but you know how that goes!
I don't have the time to work on cars like I used to, and Greasy's is 1 hour away from me, and I don't have the time to go that route either.
The only good thing is I do have another car to use if need be, but I am stuck in a lot of stop and go traffic since I work in Boston and it is not like it is ever easy to pull over when you are on surface roads without creating a huge mess Last time the car nearly broke (near overheating 2nd, time) down I got plenty of fingers for the jam I created and some of those people looked like they wanted to stab me
Old May 3, 2011 | 06:46 PM
Evasive's Avatar
Evasive
At this point, it looks like you took care of everything that could possibly go wrong with the car. On the other hand, it looks like you got an excellent deal on it though so you might be able to get close to what you've put in it.
Old May 4, 2011 | 01:08 PM
mini53's Avatar
mini53
Thanks, yeah I looked at other listings on the market place and I see that same year cars with similar specs are having 15k or so asking price. So I wonder if 11k would be a fair price or not considering the mileage.
Attached Thumbnails Ok, I think I give up :)-imag0214small.jpg   Ok, I think I give up :)-imag0216small.jpg   Ok, I think I give up :)-imag0217small.jpg
RobbyD
Jan 29, 2019 01:22 PM
Alpha Motoring
Nov 10, 2015 07:08 AM
Emnotek
Sep 29, 2015 07:37 AM
Huskyfan
GP Talk
Sep 28, 2015 06:08 PM
daviday
Sep 25, 2015 01:31 AM
