R50/53 Name that rattle...
Name that rattle...
Looking from up under my passenger side into the side of the engine it appears to be some kind of shock just above the crank pulley. It is loose and at an idle it rattles. It has a bolt going into it on one side and it appears to have backed out some. Just wondering what this part was and what does it do. Oh by the way it's an 02 Supercharged 6 speed. Thanks!!!
Just confirming the previous two posts, its definitely your belt tensioner. Its purpose is to keep the correct tension on your belt, powering your supercharger, alternator, A/C compressor. If your tensioner lets go, there goes your belt, power and a good possibility of serious secondary damage.
Get it seen to immediately, its not something that will improve with time.
Ok I see the tensioner and it's silver and has a coil spring around it. This is right under it and is a small shock. (looks like the kind that holds the hood up) and it's loose on one end. Monday is oil change day so I'll tighten it then. Also is Mobil 1 5w30 ok? And what's a good filter? Thanks!
I would say that the tensioner comes as one unit. There are other, smarter folks here who may have better info or know with certainty.
The shock is worn out on my tensioner. Chad at Detroit Tuned diagnosed that there is no slippage and should last until I get my new pulley.
Since you are hearing noise, as others have said, there is slippage and that requires an immediate fix.
I hope it is not too painful or expensive.
Motor On!
Chris
Ok everyone, At Way Motor Works I found shock bushings for $42.00 to fix worn out bushings. I am just wondering if this shock rattles while the car is running would it be bad? I ordered a set of bushings to replace the one that out but it still makes me wonder if my shock is bad. My belt doesn't seem to be slipping. I guess I'll know when I get it off to fix it if it's bad or not.
i had an alta 15% sc pulley installed the other day on my 2006 MCSa, along with the alta tensior stop. everything went fine, but last night, i noticed at idle, there is a some rattling coming from the pulley area. when i put it drive or reverse, it gets a lot louder. is my belt tensior loose? or is it the tensior stop? at idle, the belt seemed to be turning fine, and the pulley was spinning very smoothly. i am going to record some video and post it up for you to hear.
any ideas???
any ideas???
patsum
Jun 18, 2013 04:34 AM
MINI MI
Jan 31, 2013 08:37 PM
Bponce23
Aug 21, 2012 02:47 PM
