Suspension Koni FSD's Failed ANYONE ??
Old Apr 23, 2011 | 04:47 PM
drftobin's Avatar
drftobin
Anyone have any problems with there FSD's starting to think my fronts are going, when I first drive in the morning they front suspension knocks and clunks but after 15mins it seems to get better is that a sign there on there way out?
Old Apr 23, 2011 | 05:51 PM
HRM's Avatar
HRM
I have heard them failing, but clunks are not what I would associate with a bad shock. Usually there is leaking fluid and lots of bounce. I would look at bushings that may be going bad or need grease at least.
Old Apr 24, 2011 | 08:06 AM
drftobin's Avatar
drftobin
Everything else is new. EVERYTHING??
Old Apr 24, 2011 | 08:20 AM
HRM's Avatar
HRM
Top shock mounts?
They may be bad, as I said it has happened, but clunking isn't what I think of.
Old Apr 24, 2011 | 08:58 AM
Crashton's Avatar
Crashton
I think a good place to start is with the suspension bushings. Inspect them all & go from there. What year is your MINI & how many miles has it traveled? If you have a lot the lower control arm bushing could be the source of the noise.
Old Apr 24, 2011 | 10:37 AM
MINI33342's Avatar
MINI33342
Old Apr 24, 2011 | 10:50 AM
rkw's Avatar
rkw
The passenger side engine mount can also clunk if it failed.
Old Apr 24, 2011 | 11:15 AM
MrCooperS's Avatar
MrCooperS
Moderator
+1 I'm hoping it's not the FSDs. I was thinking of getting a set of those!
Old Apr 24, 2011 | 06:11 PM
drftobin's Avatar
drftobin
Engine mounts new TSW, Lower CAB's new powerflex , Upper Strut mounts new IE fixed camber plates with new Z4 bushings, sway bar end links new, both ball joints on the side of the noise are new! cars an 05 with 38,000 on it, I'm at a loss! At the shop I work at we had a benz we were selling same deal changed everything chasing a knocking clunking finely the boss said screw it and we did the shocks and the noise when away. Thats what is starting to make me think front struts???
Old Apr 24, 2011 | 08:25 PM
MrCooperS's Avatar
MrCooperS
Moderator
If it is, send them in. Lifetime warranty!
Old Apr 25, 2011 | 05:41 PM
drftobin's Avatar
drftobin
Yup searching for my receipt
Old May 2, 2011 | 09:42 AM
'06Mini's Avatar
'06Mini
Other than clunking (which may or may not be the shock), how did the FSDs work for you? I'm getting ready to change out the shocks and struts on my wife's 06 at 55K and want something that is at least a comfortable as the stock struts.
Old May 2, 2011 | 09:50 AM
drftobin's Avatar
drftobin
They are great
Old May 8, 2011 | 11:24 AM
rhafe's Avatar
rhafe
Originally Posted by drftobin
They are great
+1
Old May 12, 2011 | 06:48 PM
drftobin's Avatar
drftobin
FSD's on back order from KONI
Old May 12, 2011 | 06:57 PM
HRM's Avatar
HRM
Have you inspected the shocks. I am thinking if you can't see a leak, it has a full range of motion, it is less likely to be the shock. I guess internal things can break and bang around, but with all the goo, I don't know how much sound they can produce.
Don't worry too much, I was wrong once in 1983, so it can happen, but I am having a hard time with a clunking shock if it looks perfect.
Old May 12, 2011 | 07:25 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Not from WMW
Old May 16, 2011 | 10:52 PM
KC Jr 54's Avatar
KC Jr 54
Double check the tightness of your sway bar endlinks.
Old May 17, 2011 | 08:49 AM
ggcadc's Avatar
ggcadc
I would think hats, spring perch, knuckle, check all those, even a completely blown shock doesnt clunk, that merc may have had something loose that was fixed during the re-install process.
I would go through with a pry bar and torque wrench and check everything is tight.
Old May 19, 2011 | 09:13 AM
RedSkunk's Avatar
RedSkunk
bingo. Start with the free, easy and most likely culprits first.
Old May 23, 2011 | 02:16 PM
MrCooperS's Avatar
MrCooperS
Moderator
Originally Posted by WayMotorWorks
Not from WMW
You do warranty returns?
Old May 23, 2011 | 09:02 PM
rkw's Avatar
rkw
Have you positively identified the FSDs as being source of the clunk? I'm skeptical that they are causing it, but if you still have the original shocks, swap them back in. If the clunk goes away, then the FSDs may have been the problem and you'll have them ready to ship out. If the clunk is still there, you'll know that you have more to investigate.
Old May 23, 2011 | 09:10 PM
MrCooperS's Avatar
MrCooperS
Moderator
Tell that to the OP. I don't have FSDs.
Old May 24, 2011 | 10:20 PM
Bandeth's Avatar
Bandeth
My car does the same thing. i can hear it from the rear and i took it to MiniWorx in Redondo Beach. The guys there lube up the rear suspension and still the clunking noise persist. They did end up fixing my brake sensor light problem for me. I told them maybe its the bushing on the Ireland Sway Bar, they say maybe it is from the aftermarket bushings. Tough price to pay for the great handling, nothing loud music in your car cant overcome. Cool peeps if you guys need work done to your car. Although i was charge for their "noise" inspection to my suspension, the car still made the same noise as i left.
Old May 31, 2011 | 03:13 PM
drftobin's Avatar
drftobin
The saga continues WTF!!!! replaced the FSD's Saturday still there clunk clunk Its driving my CRAZY AHHHHHHHHH . Did the whole pry bar torque wrench thing after the Control arm bushings did not solve it. Unless some thing is bent I don't know where else to look??? Its been on the lift at the shop I'm at, like five time now we are all stupefied!!! Or just stupid ??? Now that its HOT here the noise is not as loud but still there????? I'm lost!!!
