Door is not flush to the body.
I'm not sure what may have happened. But I just noticed that the my driver side door is slightly bulged out. It closes and locks but you can see the door is not flush to the body when closed.
I haven't brought the car into the dealer yet but I have a feeling this might cost a pretty penny to fix.
Anyone else ever experience this issue?
You can adjust the front of the door by repositioning the door hinges, or adding shims if necessary.
You can adjust the back of the door by repositioning the door lock striker.
If you move the hinges or striker much, you might expose bare metal that will need to be painted to protect from rusting.
The door gap is supposed to be about 4 mm front and back, and it's supposed to be flush with the body in front of and behind it.
hmmmm
doors are very adjustable position wise .. but ..
was it OK at delivery or is this a new buy that you think you just noticed?
Or was there an 'event'? wind grabbing a door and slamming it against the stops can do bad things
Which end is off? Pictures help a lot.
Navigation & Audio HK Replacement With New Components
Filmy
15
Jun 6, 2023 06:27 AM
sempaipaul
Oct 26, 2015 05:56 PM
