R50/53 any tips to reach the airbag control unit/module?
Old Apr 6, 2011 | 06:35 PM
buggyeye401's Avatar
buggyeye401
what's up guys!
dealer told me today i have to replace air bag control unit/module, they're trying to charge me an arm/leg, but i found a used unit on ebay for $70 so i figured i'd do it myself, any great tips to get to it would be great..do i really need to remove both front seat/rear to get to it? i read somewhere that its in front of the e-brake? Thanks in advance
Old Apr 6, 2011 | 07:26 PM
Densmini's Avatar
Densmini
You might not like my method, but here goes: I removed the driver's seat, the handbrake surround and the front shifter surround/cup holders. I then cut the carpet in a straight line right down the center from the shifter edge to the handbrake edge. I pulled it back until I could get my wrench on the nuts and swapped it out. I then used weatherstrip adhesive to glue the carpet back together. 2 years later the cut is nearly invisible.
Old Apr 6, 2011 | 08:16 PM
firehawk618's Avatar
firehawk618
Yup, slit the carpet down the center from the console to shifter, then just peel it back to get the 3 nuts.
You might not like this....but i'm almost 100 percent certain that a used airbag module will throw codes because they're not married to the rest of the car. AKA vin mismatch......
The ONLY way around it is either a new one, or find a place that specializes in refurbishing your old one.
Old Apr 6, 2011 | 08:23 PM
Densmini's Avatar
Densmini
I used a service I found via eBay to reset my module. Very happy with the results.
Old Apr 13, 2011 | 08:42 AM
buggyeye401
easiest way to get to airbag control unit?
hi all,
my airbag unit is defected and needs to be replace andthe dealer is charging me over $700 to replace it. I bought a used unit for $70 and would to do it myself. any tips? or do i really need to tear out all the seats and carpet?
thanks in advance for any feedbacks!
Old Apr 13, 2011 | 08:46 AM
buggyeye401
but can't the unit be reset by the dealer? after all, the tech that told me the wrong also advised me that i can find a used one from a junk yard so i'm assuming it is resettlable? since he did give me the option of finding a used one?
Old Apr 13, 2011 | 09:09 AM
Densmini's Avatar
Densmini
NOTE: all of the following is only in my humble opinion: I don't know if the module is tied to the car's VIN. Yes, the dealer should be able to reset the module. In fact, I think you can do it yourself, by getting the proper OBD cable and Ediabas or other program. There is also a BMW airbag-specific diagnostic and reset tool called "Memoscan" which I used to turn my light off after discovering a deployed seatbelt tensioner.
AFAIK, the module will accept 3 resets, storing those codes, before it becomes inoperable.
No animals were harmed in the making of this reply.
Old Apr 13, 2011 | 09:57 AM
moreorless's Avatar
moreorless
Um
Old Apr 13, 2011 | 10:38 AM
MLPearson79's Avatar
MLPearson79
Duplicate threads merged.
Old Apr 13, 2011 | 02:21 PM
buggyeye401
yea sorry about that, i didn't realized i posted it...i just finished swappin the motor which got my head spinning from the $_$ i was losing hahahaa..but thanks all for posting, i'm going going the route of slitting the carpet, i don't car for it much...i'm sure its minimal as you guys mention.
molala
Oct 2, 2015 01:53 PM
KristaMcCoy
Sep 12, 2015 05:37 PM
Suspension Products
Sep 3, 2015 09:41 AM
Ntety
Sep 2, 2015 08:39 PM
Sep 2, 2015 11:15 AM
