R50/53 JCW Fuel Injector install help needed ASAP!
Old Apr 3, 2011 | 03:22 PM
jeff323's Avatar
jeff323
I am looking for some help with the installation of my JCW fuel injectors. Basically the problem or concern I have is with the re installation of the fuel rail. When I took the rail off, the factory S injectors were very snug inside the head making removal of the rail a little hard. I replaced all the injectors on the rail no problem, but now I feel as though the new injectors don't go in as far into the head as the old ones did. After several attempts to seat them deeper, I decided to try and just bolt down the rail and see if that would help seat them better, but I am feeling a little uneasy about that method. I went as far as starting the car up and letting it run a bit and I don't see any leaks, but again I'm not feeling over confident I did it right. I have the bentley manual, but its very vague at this point. It just says to reinstall the rail.
Any help would be greatly appreciated!
Old Apr 3, 2011 | 03:35 PM
Revolution Mini Works's Avatar
check ALL YOUR OLD INJECTORS to make SURE THE BOTTOM O-rings are still on the injectors
you should have used some silicon or lube to put on the o-rings so they seat easier
Old Apr 3, 2011 | 03:46 PM
jeff323's Avatar
jeff323
Thanks Jan! I actually just figured it out. It put a tiny dab of lube on the o rings and the reinstalled them again. They went in like butter.
Old Apr 3, 2011 | 04:04 PM
just make sure you didn't tear the o-rings or your problems have just began
Old Apr 3, 2011 | 04:14 PM
jeff323's Avatar
jeff323
Haha! Yeah, no all is good.
iggi
18
Feb 9, 2026 01:00 AM
1chaos52
Aug 24, 2015 01:28 PM
kpl
Aug 11, 2015 04:52 AM
