Suspension Mini-Madness rear shock bushings! Great!
Old Mar 27, 2011 | 11:11 PM
R53Warrior's Avatar
R53Warrior
nvm
Old Mar 27, 2011 | 11:31 PM
k-huevo's Avatar
k-huevo
MINI rear struts are subjected to high side loads, restricting the strut shaft neck from pivoting creates bending stress upon the shaft, and subjects the piston to lateral stress, for which it was not designed to tolerate; it's a recipe for stiction. Softer is better for this application.
Old Mar 28, 2011 | 04:27 AM
yetti96's Avatar
yetti96
I might need to get some of these, the ride is horrible in my 2002, even with 40k miles on it. So the ride hight is more consistent, smoother or more predictable?
Old Mar 28, 2011 | 09:23 AM
R53Warrior's Avatar
R53Warrior
nvm
Old Mar 28, 2011 | 09:56 AM
k-huevo's Avatar
k-huevo
Originally Posted by R53Warrior
The bushings still allow for lateral movement similar to the stock bushings...The main thing is I can drive with a person in the back seat without rubbing. Before that was impossible.
Increased side load will become apparent in time.
The upper mount is not the appropriate location for a spacer to alter ride height due to spring choice, sacked springs, and/or body trim contact from tire & wheel dimensions. Under the lower spring coil is the place for shims.
Old Mar 28, 2011 | 12:24 PM
R53Warrior's Avatar
R53Warrior
Old Mar 28, 2011 | 02:41 PM
MINIdave's Avatar
MINIdave
Why would there be any side loading up there? That's right under the nut, isn't it? Seems to me that's a good place to have a stiff bushing....the shaft of the shock is still free to move about, only the end is pinned, it can still pivot tho can't it?
I don't see a downside here unless it increases NVH....
Old Mar 29, 2011 | 10:10 AM
k-huevo's Avatar
k-huevo
Its not a spacer. Its the same size as a brand new OEM bushing. The OEM bushing material had degraded to the point where it caused sagging. Have you installed these bushings or felt the lateral resistance/movement with your own hands? If not please stop speculating.
It is the springs that have sagged if the car is bottoming out, the poly bushing is acting as a shim in this case by not compressing. Yes I have first hand experience.
The trailing arm is attached forward of the lower shock mount, the top mount is attached forward of the lower mount, as the lower mount location rises, the top of the strut shaft must tilt, there is a metal spacer withing the upper mount bushing that is bolted against a washer collar and the upper spring perch creating a fairly rigid connection to the shaft. The ID shape of the washer/collar and OD neck of the OEM strut shaft (not Bilstein's BTW, which is square, and will be rigid), will allow a minor amount of give, but not enough to compensate for an upper spring hat that cannot move in its intended range of motion. There is a reason why the rear OEM spring hat has a radius edge, and the contact surface is less than the bushing's, that is so it can roll into the upper bushing for less resistance. The washer under the top strut nut is dished to allow less resistance to side movements also. When the shaft is not allowed to tilt feely, this increases side load on the shaft neck, the shaft against internals, its seals, and the piston within. These forces exist with the OEM strut as well, and they increase when the car is lowered, ideally this effect should be minimized. A coilover spring hat with inadequate clearance, a spring hat that is too wide, or a poly bushing that does not allow sufficient compression on the hat's edge, are movement inhibiting examples.
Note the conflicting report from the OP, we're told it does not inhibit movement, but we are shown the lack of compressibiliy in a photo.
Old Mar 29, 2011 | 10:37 AM
JAB 67's Avatar
JAB 67
Question: In order to replace/install these bushings, is it necessary to decompress and remove the spring from the strut assembly?
Old Mar 29, 2011 | 01:55 PM
R53Warrior's Avatar
R53Warrior
Old Mar 29, 2011 | 01:56 PM
R53Warrior's Avatar
R53Warrior
Old Mar 29, 2011 | 03:01 PM
JAB 67's Avatar
JAB 67
Thanks.
Old Mar 29, 2011 | 03:42 PM
M3NTAL's Avatar
M3NTAL
R53Warrior -
k-huevo is correct with his answer. I have personal experience with snapping a shock in half due to the side load caused by the top hat not articulating when the suspension compresses. I noticed no issues while driving under the condition until the shock finally snapped.
The suspension doesn't move in a linear fashion when compressing due to the geometry of the rear trailing arm in relation to the upper mount.
Looking at your suspension from the back of your car at full droop it looks like this
as the suspension travels upwards, the relation of the two straightens out
[] l l []
Where the shock passes through the top hat is now side loaded because it has nowhere to go.
If you look at other designs that ditch the factory top hat you'll notice that they go with something that is more along the lines of a heim joint / spherical bushing
Old Mar 29, 2011 | 03:44 PM
R53Warrior's Avatar
R53Warrior
Old Mar 29, 2011 | 04:24 PM
R53Warrior's Avatar
R53Warrior
Old Mar 29, 2011 | 05:01 PM
MINI33342's Avatar
MINI33342
I am surprised that you work for a MINI dealer and are not more informed on the mechanics of the MINI.
Keith is right on about the bushing, but then I guess you will find out soon enough.
And I am really surprised on the language in your signature pic...........
Old Mar 29, 2011 | 05:04 PM
R53Warrior's Avatar
R53Warrior
Old Mar 29, 2011 | 08:05 PM
MINIdave's Avatar
MINIdave
Thanks for the explanation, khuevo!
Seems R53 warrior picked up his posts and just went home.....
W0TM8
Dec 19, 2019 07:50 AM
Toolman
Jan 20, 2016 06:50 AM
Emnotek
Aug 13, 2015 05:47 PM
Aug 11, 2015 09:01 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
