R55 What is that whining/whirring noise?
Old Mar 24, 2011 | 06:52 PM
DomesticMuscle's Avatar
DomesticMuscle
When I hit the unlock button after the car has been off for a bit of time. I hear this kind of high pitched whirring or whining noise coming from the interior. What is it?
Old Mar 24, 2011 | 07:10 PM
timfitz63's Avatar
timfitz63
Yeah, I noticed that too when I first got mine. I believe it's the fuel pump pressurizing the system. It's perfectly normal.
Old Mar 24, 2011 | 08:16 PM
DomesticMuscle
Ah so the system depressurizes after it sits for a bit. My Corvette does something similar when you hit the ignition. If it has been sitting you will hear the fuel pump kickin just before the starter engages. This is probably similar but due to the higher fuel pressures of a direct injected engine it does it once it senses or thinks you may wish to start the car in the immediate future.
Old Mar 24, 2011 | 08:49 PM
MINIdave's Avatar
MINIdave
Not only that, but if you sit in the car after you shut it down with everything off, after a minute or two you'll hear a series of "pop,clunk" as a valve opens and closes to depressurize the system.....mine does it 6 or 7 times......
Old Mar 28, 2011 | 11:47 PM
gr8ful's Avatar
gr8ful
I named my R55s "Mumbles" cause of all the wierd noises.
Old Apr 3, 2011 | 07:47 PM
klricks's Avatar
klricks
I have a noise like that. It turns out that on my Clubman it's the CD player making a noise when I unlock the doors AND when there is no CD loaded in the player. Acts like it is trying to spin up and/or read a CD...Seems to move the head back an forth full travel a couple of times then gives up. I am not sure it happens all the time or not? No noise at all if a CD is in the player.
scfiveo
Sep 27, 2019 02:27 PM
unxpectederror
Oct 22, 2015 12:16 PM
Qik420
Oct 4, 2015 08:19 PM
Qik420
Oct 1, 2015 12:02 PM
Miniwaukee
Sep 29, 2015 09:22 AM
