R50/53 This ever happen to your MINI?
Old Jan 14, 2004 | 06:52 AM
d2mini's Avatar
d2mini
At my office, I have to reverse out of my parking space and keep reversing down a narrow area of about 10 car lengths before i can then pull out foward into the rest of the parking lot. Anyway, when I'm reversing out I sometimes do it at around 10mph which is a little fast for reversing. Then when i hit the brakes and turn I sometimes get an awful crunching sound that I'm assuming is the ABS? Just wondering why it's doing it at such a slow speed when the tires obviously aren't sliding or anything. And yesterday when it happened, both the tire pressure monitor light and the traction control light came on on the speedo and they stayed on until i turned the car off and back on again. Is this normal? Happen to anyone else?
Thanks!
Old Jan 14, 2004 | 07:07 AM
Mini_Street_Racer's Avatar
Mini_Street_Racer
no it might be something else. I back up at similar speeds and it hasn't happened to me.
Doug, (dude who was banned from here) actually pulls reverse donuts in his MINI Cooper and no warning lights come up. you might want to get it checked.
Old Jan 14, 2004 | 07:10 AM
C4's Avatar
C4
I also have a '04 CR/W MCS with 3,500 miles and this has never happened to me before, so it is certainly not normal to have the ASC and Tire pressure lights to come on when backing out and applying light brake pressure.
The problem could be related to a faulty sensor or a combination of things, for instance a sticking rear brake caliper. I assume your car has DSC and 17" S-Lites which have been known to trigger DSC light problems.
Upon starting the car you will probably hear a "clunk" which indicates the computer self test of the ABS system which is normal.
Anyhow, take it back to the dealer and have them check your car with a fine tooth comb. Probably is nothing serious.
Old Jan 14, 2004 | 07:27 AM
IanF's Avatar
IanF
That sounds weird and I'd get it checked out. Could be the self-adjusting mechanism for the emergency brakes or maybe even a CV joint.
Get your service rep in the car with you and try to reproduce the sound.
Old Jul 25, 2007 | 08:19 PM
allythom's Avatar
allythom
Reviving a thread from the dead...
This exact thing happened to me today in my 05 MCS as I was parking for work. I was searching to see if anyone else had experienced it.
Reversed at moderate speed, braked lightly, get ABS 'chatter' and both the the TPM and TCS warning lights came on. Weird. I did notice that I had reversed through a small puddle, but I think that's immaterial, traction was not affected, the braking was by no means sufficient to cause a skid.
Haven't tried reproducing, warning lights cleared when I restarted the car. Tire pressures were normal (I checked this evening when I got back to the car)
Anyone else seen this ?
Alun
Old Jul 25, 2007 | 11:09 PM
Jurrell's Avatar
Jurrell
From: Millersville, Maryland (stationed in Beaufort, SC)
Maybe you almost stalled out. My car's tire and traction control light comes on sometimes when I almost stall out.
Old Jul 25, 2007 | 11:41 PM
MikeL's Avatar
MikeL
That exact thing happened to me a few days ago. Shut off and restarted, lights went out and haven't come back on since. I thought maybe it activated the DSC due to the quick turn.
Old Jul 26, 2007 | 10:01 AM
redrocket's Avatar
redrocket
i dont have it in reverse but say i take a u turn a wee bit to agressive and i tap the breaks, i end up getting ABS activation and by no means am i going fast enough nor braking hard enough to need it.
Motown
Apr 20, 2018 09:31 AM
Colt45Magnus
Aug 12, 2015 06:43 AM
dchang0
Aug 10, 2015 03:37 PM
1964geo
Aug 10, 2015 06:22 AM
nismo4life
Aug 5, 2015 08:31 AM
