R50/53 Replacing shocks and struts. Should I do bushings too?
Old Mar 17, 2011 | 03:34 PM
Minibeagle's Avatar
Minibeagle
I will be replacing the shicks on my 2002 Cooper S shortly and am wondering if I should take the opportunity to have bushings replaced at the same time.
Car has roughly 100K km (63k miles) and is a year-long daily driver.
Also, are urethane bushings really worth the xtra $?
Old Mar 17, 2011 | 06:21 PM
NMgokart's Avatar
NMgokart
Probably not a bad idea, since someone will already be "in the neighborhood".
The urethane bushings are a matter of taste.... they are considerably stiffer than stock and your ride will be affected. If you (and potential passengers) can handle the bone-jarring ride, go for it.
Old Mar 17, 2011 | 07:08 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
With that many miles its a good idea to replace them, and the Powerflex control arm bushings is def the way to go.
Old Mar 17, 2011 | 07:32 PM
JIMINNI's Avatar
JIMINNI
Interesting you post this today. Just helped my mechanic remove a 02 clutch today, need to drop the subframe to do it, the control arm bushings were completely toast, as were the upper and lower motor mounts. This was on a car with only 60k miles. If I were you I would replace all the bushings, motor mounts, ball joints including the tie rods. Get a good aligment and you will be amazed PS, dont waste your time on OEM bushings, go Powerflex You will love them.
Old Mar 28, 2011 | 09:19 AM
ufomini's Avatar
ufomini
I have the Powerflex bushings and I can not tell much difference between them and OEM.
They should last twice as long though!!!!!!
Toolman
Jan 20, 2016 06:50 AM
silence2-38554
Nov 12, 2015 09:39 AM
Emnotek
Aug 13, 2015 05:47 PM
minipopkart
Aug 13, 2015 05:22 AM
PelicanParts.com
Aug 4, 2015 02:45 PM
