R55 Who has modded their JCW Clubbie?
Old Mar 15, 2011 | 11:55 PM
Autoxser1975's Avatar
Autoxser1975
I'm just wondering what's out there and if it's really necessary to mod the engine and suspension of the JCW cars.
Old Mar 16, 2011 | 09:46 AM
Zephyrgtw's Avatar
Zephyrgtw
Necessary? - No
Fun? - Yes
Addicting? - Probably
The JCW Clubman from the factory is a fantastic car. Most fun car I have ever driven (list is long).... Then you start reading NAM and other sites - and start thinking: "Oh... I WANT that too"....
Enjoy you car as is. Take it to a Car Control Clinic; do an HPDE. You'll have a blast. (Learn the handling dynamics - especially the: 'from the factroy dialed-in understeer'; and try to get the car to bring the back end around a bit with judicious throttle changes mid corner.)
Then - if you want more... it's out there.
I think most people agree: best 1st mod is an adjustable Rear Sway Bar. The softest after-market bar on the softest setting changes the performance of the car = grin inducing.
These are great machines. No matter your driving style - you will be fulfulled. Track junkies will probably mod the most. If the car is mostly a Daily Driver with a few spirited corners and on-ramps - you don't need to do anything. Then - there is everything in between...
Old Mar 16, 2011 | 10:34 AM
Zephyrgtw's Avatar
Zephyrgtw
Actually ... I probably should have taken not of your sign-in name first....
If "Autoxser1975" is any indication - then you probably know more than I do about understeer/oversteer/throttle-steer...
Get a bigger RSB - even if you already have the JCW suspension (it's 18.5mm in the back - and obviously not adjustable). JCW springs are good. Others can be better. If you want more power - consider an RMW tune.
'nuf said
Old Mar 16, 2011 | 10:38 AM
Zephyrgtw's Avatar
Zephyrgtw
Actually ... I probably should have taken note of your sign-in name first....
If "Autoxser1975" is any indication - then you probably know more than I do about understeer/oversteer/throttle-steer etc...
Get a bigger RSB - even if you already have the JCW suspension (it's 18.5mm in the back - and obviously not adjustable). JCW springs are good. Others can be better. If you want more power - consider an RMW tune. Lighter wheels; better summer tires; FMIC is good...
'nuf said
Old Mar 16, 2011 | 04:30 PM
Autoxser1975
Thanks for the info Zephyr. I'll have to google RMW tune. I've already upgraded wheels and tires and am purchasing springs too. BTW which Konig wheels did you buy. I own the Lace wheels. I've really been checking out the Alta website alot. Tons of goodies.
Old Mar 16, 2011 | 06:19 PM
Zephyrgtw's Avatar
Zephyrgtw
Alta is great...
www.waymotorworks.com also great
www.revolutionmotorworks.com is the sire for the RMW Tune
And - for RMW tune info - check these threads:
https://www.northamericanmotoring.co...lash-tool.html
and
https://www.northamericanmotoring.co...k-into-it.html
I can't remember the name of the Konigs I purchase... Unfortunately - they went out of production (so I better not ding one). They are not on my signature picture... I'll have to update that as soon as I put on the Springs that are in the mail - and I go back to the summer tires.
Sounds like you're having fun!
Old Mar 16, 2011 | 06:43 PM
Autoxser1975
Thanks for all the good info once again.
Old Mar 16, 2011 | 08:08 PM
LV2CRNR's Avatar
LV2CRNR
I have done Helix short throw shifter, Blow off valve, DDM cold air intake, R113 Black 18" wheels, Eibach pro kit drop, and a few other things.
Old Mar 16, 2011 | 08:12 PM
Autoxser1975
How do you like the Eibach springs? What was the total drop after install? Any pics of your car?
Old Mar 17, 2011 | 11:07 AM
LV2CRNR's Avatar
LV2CRNR
I like the springs a lot, still make it over speed bumps. Took care of the ugly wheel gap when I put the 18's on. I will post pics of car before and after drop.
Old Mar 17, 2011 | 11:19 AM
LV2CRNR's Avatar
LV2CRNR
after eibach pro kit drop:
Pic of my car the day I got it to show you how different it looks now:
Old Mar 17, 2011 | 11:22 AM
LV2CRNR's Avatar
LV2CRNR
my next mod is stainless brake lines before I hit the dragon.
Old Mar 20, 2011 | 01:44 AM
Autoxser1975
I purchased an Alta 22MM RSB too. Gonna have it installed with the springs. I've also been lurking the For Sale section on here and found a few more bits I'd like to have. But next performance mod will probably be an Alta CAI. Next year definitely gonna have to get an Accessport.
Old Apr 4, 2011 | 11:44 AM
LiLReD1's Avatar
LiLReD1
H&R coil-overs, 16.5lbs wheels, intake, exhaust, pipes, FMIC, AccessPORT, 220+whp, 240+wtrq... I'm just getting started.
sevin
May 2, 2026 06:11 AM
Motown
Apr 20, 2018 09:31 AM
Aug 19, 2015 12:51 PM
minipopkart
Aug 13, 2015 05:22 AM
