Suspension Brake Bedding In?
Old Mar 14, 2011 | 05:29 PM
Dwight Walhood's Avatar
Dwight Walhood
Brake Bedding In?
I just installed EBC Sport front rotors and Red Stuff pads and have a question about bedding them in. EBC says it can take up to 1K miles, but how do you know when they've finished the process? I'm guessing, but is it when you no longer see the cross hatching on the rotors and the wear pattern is smooth and even? At 300mi. I've had no squeaks or other noises, the pedal feel just keeps getting better all the time, that cross hatching is nearly gone and the wear pattern is smoothing out. Haven't had to brake really hard yet, but I'm using the brakes as much as possible at varying speeds. Am I getting close?
Old Mar 14, 2011 | 11:34 PM
smoke05S's Avatar
smoke05S
You can take a pad out and look at it. When they are new they have that bevel cut so that only the middle third of the pad is used. As it beds in, the contact patch gets larger. The feel gets better because the useable area is getting larger. If the whole pad is being used you are there. It's a little more complicated than that because there is some temperature cycling that needs to take place but from how you described I think you should be good to go as long as the whole pad is being used.
Old Mar 15, 2011 | 08:46 AM
Dwight Walhood
Thanks tons Smoke! I guess there is a light at the end of this long tunnel, lol.
Old Mar 16, 2011 | 06:54 AM
Dwight Walhood
Checked the pads like you said and the bevels on the leading and trailing edges are now gone with the pads in full contact. Cross hatching appears about 3/4 gone, too, so I guess I'm about there. Thanks again!
CRC
Dec 26, 2015 11:30 AM
Sc00terbum
Sep 11, 2015 07:17 AM
Sep 10, 2015 10:52 AM
Tinklespout
16
Sep 6, 2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
