R50/53 What is the normal range for Water Temperature?
Old Feb 22, 2011 | 10:44 PM
Checkmate_2006's Avatar
Checkmate_2006
Hey everyone,
I just installed my water temp gauge over the weekend and I want to know if the water temp range is okay. It seems to fluctuate between 180-200, but hovers mostly around 180-190. I am not sure if this is normal or not. I just drove it around a couple blocks and then back home. I haven't been able to find out what is the normal operating temperature and if any fluctuation is normal. Thanks in advance.
dp
Old Feb 22, 2011 | 10:52 PM
Eric_Rowland's Avatar
Eric_Rowland
Fluctuation is normal. OEM gauges tend to eliminate normal variability to sooth the minds of the masses. Mine generally runs at 193 which makes sense given the 190 thermostat (though I swear it used to run in the 180's), but can easily hit the 200s in stop and go. The fan goes on low speed at 221F, off at 214F.
Old Feb 23, 2011 | 04:53 AM
ofioliti's Avatar
ofioliti
That's the same range I get on the Scangauge. You're ok.
Old Feb 23, 2011 | 08:07 AM
tcscb1963's Avatar
tcscb1963
Plus 1
silence2-38554
98
Sep 21, 2016 02:52 PM
danielbrookes_9
Oct 3, 2015 12:51 PM
finn
Aug 21, 2015 07:59 AM
tylewis
Aug 18, 2015 06:53 AM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
