Electrical Angel Eye Parking/Turn Lamps
If the halo is no longer lit up, then you probably have a burnt out LED. You can buy replacement LEDs at MINIMania for $26 if it is the LED that is burned out.
Well traced down the reason the LED's wouldnt light up connection was corroded. However the housing are melted on the inside above the turn indicator. Not to mention the previous owner broke the bracket off and used caulking to hold it in. I just switched back to a set aftermarket oem replacement and used the led bulbs no halo but they look pretty good.
Chibi2
May 19, 2016 03:46 PM
Alpha Motoring
Nov 10, 2015 07:08 AM
Oct 1, 2015 12:13 PM
Alpha Motoring
Oct 1, 2015 10:30 AM
Sep 29, 2015 12:11 PM
