Weight and Speed Ratings
Old Feb 21, 2011 | 09:59 AM
wolfesmini's Avatar
wolfesmini
I've read many posts on replacing RF with non-RF which I plan on doing, but the one thing no one has mentioned...are you purchasing tires with the weight and speed rating suggested by BMW? If not how far off the rating did you go?
Mine are rated 87v's and am wondering how low I can go.
Old Feb 21, 2011 | 05:35 PM
MP1.6T's Avatar
MP1.6T
I always follow the vehicle sticker
minimum, both on weight class and speed rating. On prior vehicles I have noticed the weight class can vary with different OEM diameters too (and not always higher w/ lower profiles like I would have guessed). Most relevant for high speed, high temp, high load use, but why compromise. So many good tire choices out there.
Old Feb 21, 2011 | 08:32 PM
slinger688's Avatar
slinger688
I would agree with those as the minimum requirements. I would be weary going below those.
Old Feb 21, 2011 | 09:42 PM
hsautocrosser's Avatar
hsautocrosser
My manual has approved examples a lot lower than 87V.
Old Feb 22, 2011 | 09:38 AM
Project_2501's Avatar
Project_2501
Honestly, most tires within a size range will have similar load ratings. Same goes for wheels you're going to be interested in running.
This is a case of worrying too much. The car weighs 2650lbs, it's rather light weight compared to a lot of other modern cars, that also use 205/45 size tires for 17" wheels (such as a VW Passat).
Unless you're trying to cheap out on tires? But that's foolish - what's your life worth?
Old Feb 22, 2011 | 11:33 AM
wolfesmini's Avatar
wolfesmini
One of the local shops told me I could probably get away with next lower speed rating but cautioned against going lower on the weight.
Another shop quoted me 87H tires and am thinking that might be too low. However, its a difference of 45 dollars a tire.
Supertractor3
Apr 7, 2017 11:16 AM
USA-RET
Nov 9, 2015 07:27 PM
Gremothra
Sep 9, 2015 08:42 PM
dandw2
Sep 6, 2015 03:14 PM
Ntety
Sep 2, 2015 08:39 PM
