Electrical 12V Switched/Ignition source in Boot Area
Old Feb 21, 2011 | 12:38 AM
scolburn79's Avatar
scolburn79
Hi guys,
As the title says, can anyone tell me if their is a 12v switched/ignition source in the boot area at all? I don't really want to have to run one from the front if I can help it. Thanks in advance
Old Feb 21, 2011 | 12:50 AM
rkw's Avatar
rkw
What year and model? There should be one, except for a period I believe in 2003 when MINI's were built without it. If you have an owner's manual it should be described there, including a drawing of where it is.
Old Feb 21, 2011 | 01:55 AM
scolburn79's Avatar
scolburn79
Hi,
Mine is an 04 models cooper s. I don't think it is there. Mine is the version just before they swapped to the facelift model.
Old Feb 21, 2011 | 02:41 AM
rkw's Avatar
rkw
I can only speak for USA spec. The 04 here do have a power socket on the left side.
Old Feb 21, 2011 | 05:45 PM
MyMiniGidget's Avatar
MyMiniGidget
You could use a relay, using the antenna power (comes on if the radio is turned on with no key, but will be on any time when the key is in the ignition) to give the signal and 12v from your battery as the power. this would make it an switched/ignition wire. Just an alternative if you (like me) don't have a power outlet in the boot.
Chasp
Aug 22, 2015 01:27 PM
speedbird_1
Aug 15, 2015 04:44 PM
xraycat
Aug 12, 2015 02:36 PM
