Suspension Rear Strut Tower mount
Old Feb 14, 2011 | 04:56 PM
Ministrater's Avatar
Ministrater
Any of you guys re-used the old ones? Just curious. $124.00 each seems a bit steep for these little guys.
Old Feb 14, 2011 | 06:18 PM
R53Warrior's Avatar
R53Warrior
Can you be more specific which part you are talking about? The rear upper shock perch is really just a plate and two rubber bushings that are sandwiched on it. Really those bushings are the only thing that would be worth replacing either with new oem or mini-madness poly ones.
Old Feb 14, 2011 | 07:03 PM
Ministrater
Yes that is the exact part I was referring to. Thank you for the bushing idea. I'll check into this for sure. Sorry for the lame terminology but I didn't have my Bentley handy.
Old Feb 16, 2011 | 07:27 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Yes most people just reuse the stock ones.
Old Feb 18, 2011 | 03:14 PM
Ministrater
Thanks Way. And thank you for the prompt delivery of the Koni FSD's. Will be installing these this weekend along with the fixed IRE plates and the suggested set of rear shock bushings from Mini-Madness (thanks again Warrior).
Old Feb 18, 2011 | 04:14 PM
R53Warrior's Avatar
R53Warrior
http://www.flickr.com/photos/57730108@N07/5456759913/http://www.flickr.com/photos/57730108@N07/5456759913/ by http://www.flickr.com/people/57730108@N07/, on Flickr
Old Sep 29, 2011 | 05:08 AM
mini_macky's Avatar
mini_macky
I have a clunk in the rear suspension & me thinks its from the rear upper shock mount bushings. Has anyone tried the powerflex ones?
Old Nov 4, 2011 | 10:01 PM
mini_macky's Avatar
mini_macky
Ok, well the new powerflex bushings didn't do anything to get rid of the clunk from the rear. It really sounds like its coming from the rear left strut mounts (as the clunk sounds like its coming from behind the rear quarter panel) but the bushings are new & the mounts are ok.
Old Nov 15, 2011 | 01:42 PM
KC Jr 54's Avatar
KC Jr 54
If you have adjustable endlinks, it is likely those. If not, then you may need to lube the sway-bar bushings.
JaysinStrife
Suspension
Sep 7, 2015 12:52 PM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
Aug 5, 2015 02:11 PM
