Wheel & tire/Size help
Old Feb 13, 2011 | 04:55 PM
i-Mini's Avatar
i-Mini
I have a 06 R50. I'll soon need tires and currently have the stock bicycle tires on it.
Whats the widest I can go on my stock rims before i need to change those too?
-current tire is 175/65/15
Old Feb 13, 2011 | 06:46 PM
matthew-w's Avatar
matthew-w
You might find this helpful:
http://www.mini2.com/forum/faq.php?faq=faq_wheels_tyres
Old Feb 13, 2011 | 06:59 PM
kemo's Avatar
kemo
i-Mini you'll probably get a better answer to your question in the Tires, Wheels & Brakes section: https://www.northamericanmotoring.co...and-brakes-36/
Plus there are a ton of threads in that section about tire size, so you'll have lots to read through.
Old Mar 29, 2011 | 07:10 AM
mini coop's Avatar
mini coop
I run 205/55/15 on stock 5.5 inch spooler wheels. They fit well.
Old Mar 29, 2011 | 07:15 AM
i-Mini's Avatar
i-Mini
Good to know - thanks for the reply.
Old Mar 29, 2011 | 07:43 AM
davisflyer's Avatar
davisflyer
http://www.miata.net/garage/tirecalcold.html
BTW, the 205/55/15 mentioned above is a near perfect diameter with your current tires and will provide a substantial increase in tire patch width!
Old Apr 5, 2011 | 10:25 PM
daeltos's Avatar
daeltos
Could someone please post a picture of the 205/55/15 tires mounted on stock wheels?
Old Apr 6, 2011 | 02:37 AM
truckboy's Avatar
truckboy
I think you could discuss this with a good tire installer because tire dealer is the person who knows what fits best and what works best because he is facing this kind of issues on a daily basis
Old Apr 6, 2011 | 02:55 AM
slinger688's Avatar
slinger688
I is a tradeoff going to wider tires.
Wider can give you better handling but in a justa you will lose some noticeble acceleration with taller tires and mpg will fall as well due to increase rolling friction.
Old Apr 6, 2011 | 02:37 PM
howsoonisnow1985's Avatar
howsoonisnow1985
Better selection for performance tires in 205/50-15
Old Apr 6, 2011 | 07:16 PM
mini coop's Avatar
mini coop
I have the 205/55/15 tires with no noticeable decrease in acceleration. I get 40-45 mpg. The diameter is almost exact to 175/65/15 so no difference in the speedo. 205/50/15 are a little small in diameter and throws some things off although acceleration is improved due to the improved gearing ratio. You would have to decide whether this is right for you if you do not want a closer match to OEM.
Old Apr 7, 2011 | 01:27 AM
i-Mini's Avatar
i-Mini
I'm also looking to lower it (no more than an 1") so that should the trick. Now I can stick w/ harder suspension that is the stock size.
Thanks everyone for your feedback.
barnoun
Sep 17, 2018 05:04 PM
khumpert
Nov 30, 2015 11:48 AM
SosoMINI
Nov 22, 2015 03:17 PM
Aug 26, 2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
Aug 20, 2015 01:24 PM
