Drivetrain Acorns in the intake
Old Feb 10, 2011 | 07:01 PM
Kenneth Roehl's Avatar
Kenneth Roehl
Took the air filter apart on my JCW and was dumfounded to find acorns under the flat filter in the bottom half of the filter box. How do those critters get in there? This was part of the R&R to install the Alta cold side silicon tube,a real tight fit. What kind of mouse trap do I need?
Old Feb 10, 2011 | 08:19 PM
ThumperMCS's Avatar
ThumperMCS
I remember the same thing happened to someone else on here too....can't remember who though
Old Feb 10, 2011 | 08:51 PM
drewstermalloy's Avatar
drewstermalloy
Maybe squirrels carried them in there??
Old Feb 10, 2011 | 09:30 PM
Fly'n Brick's Avatar
Fly'n Brick
If it is rats or mice you are plagued with, go to
http://www.backwoodshome.com/articles2/easterly110.html for a great trap idea. If on the other hand, squirrels are up to no good you'll need a bigger barrel with something sticky in it instead of water. Squirrels are pretty nimble.
Old Feb 13, 2011 | 06:23 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Seen it happen a couple times, mice are the cause.
Old Feb 13, 2011 | 07:51 PM
dannyhavok's Avatar
dannyhavok
Not quite the same, but when I cracked open the airbox on my CBR600 F4, I found all sorts of weird stuff.. wasps, bumble bees, huge moths, etc. No wonder it wasn't running great!
Old Feb 13, 2011 | 08:58 PM
dunphyj's Avatar
dunphyj
it adds character :P
Old Feb 13, 2011 | 09:13 PM
Melangell's Avatar
Melangell
Hunt down th' critters 'n make them pay! No quarter! Argh!
Old Feb 14, 2011 | 05:34 AM
schatzy62's Avatar
schatzy62
Yeah that was me that had a real problem with them, Not mice actually it was squirrels in my case. Here is the thread with pictures.
https://www.northamericanmotoring.co...-be-wrong.html
Old Feb 14, 2011 | 07:48 AM
ChefTyler's Avatar
ChefTyler
I had field mice eat the wiring of my off-road lights on my Xterra once, sprayed the engine bay with a habanero solution and it never happened again. Not an ideal solution because of the obvious residue all over the engine bay but it worked.
Old Feb 15, 2011 | 01:32 PM
Kenneth Roehl
The solution to the chipmunks using my intake as a safe deposit box seems simple after I looked at it. I will make up a wire mesh cover for the intake at the front headlight(2009 JCW) out of 1/4" wire screen. this should let all the air in and keep the chipmunks out.Take it easy,But take it Ken R.
rtk90
Aug 29, 2019 09:08 AM
67morris
May 7, 2016 11:52 AM
Sep 22, 2015 02:05 PM
knbond1
Sep 22, 2015 06:20 AM
Sep 11, 2015 11:09 AM
