So my wife's '09 JustaCooper Clubman hit 70k miles. I've already got an oil change in mind. I recently had the tires rotated and balanced and had the alignment checked. What other maintenance should I be considering?
I am 65K and figured plugs were getting close in my MCS but when I took the coil off I realized that I needed a completely different spark plug socket. Is mini mania the best place to get the spark plug socket? I tried the local parts store but they didnt have the right one.
do some searching. I know they look odd, but I think you can use like a 12pt 14mm or 6 point 15mm
Also maybe coolant and test the battery, especially if you are on the original.
If the car is an auto, I would change the transmission fluid (use the same MINI/factory spec fluid). Personally, I don't believe in lifetime fluids. I plan on changing it when I hit 30k.
Can I just say "Wow" I can't believe you put that much mileage on an 09 clubman. How many miles do you do a day?
