D Stock Negative Front Camber Increase
Old Jan 26, 2011 | 11:26 AM
DOC4444's Avatar
DOC4444
I was able to initially obtain close to one degree negative camber in front on my 2010 Justa by removing the plastic pins. However, after adding Bilstein HD struts and M7 strut top plates, I lost almost half a degree of that.
This is a street only car and I am just looking to get the front to 1 and 1/2 degees negative. It looks to me that one should be able to acheive this by simply elongating (grinding) the holes inboard in the strut towers that the strut studs fit through,and machining the holes in the M7 plates to allow them to be moved inboard.
I understand camber plates may be needed for more extreme negative camber settings, but I am puzzled why I have not read anything about simply elongating the holes.
Appreciate your input.
DOC
Old Jan 27, 2011 | 09:20 PM
Motoring's Avatar
Motoring
You are posting in a motorsports forum, and the rules do not allow for enlarging the holes for camber gain. there are allowances in some classes for bolting on camber plates...
ebowling
90
Aug 4, 2019 09:15 AM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
OutMotoring
Aug 6, 2015 09:32 AM
