R55 will this wheel fit on my 11 clubman S?
Old Jan 19, 2011 | 11:29 PM
since041309's Avatar
since041309
Hi guys, this is 16" wheel from older model mini.
will this wheel fit on my 11 clubman S???
I have 17" black bullet wheels but due to pothole damage i have to take it out untill it gets repaired.
thank you !
Jay.
Old Jan 20, 2011 | 03:55 AM
yetti96's Avatar
yetti96
If it is from a first gen car the lug holes might need to be drilled out to fit the 14mm bolts and not the 12mm bolts the first gen got for holding the tires on the car.
EDIT: WRONG, I was wrong and here is where it says so:
http://www.mini2.com/forum/faq.php?f...wheel_fitments
On July 12, 2006 the size of wheel bolts was changed from M12x1.5 to M14x1.25. There exists a misconception that this change in wheel bolt size precludes fitting early OEM wheels on later model cars. This is simply not true as all OEM wheels have holes large enough for either size wheel bolt.
Old Jan 20, 2011 | 05:37 AM
MI MINI S's Avatar
MI MINI S
Here is all the MINI wheel & tire info in one place.
Old Jan 20, 2011 | 08:51 AM
since041309
Thanks!!!!
thank you guys for your ansewrs!
i think they are actually 1st gen. ouch.. drilling is too much of a hassle.
i actually found that chart on mini2 forum but i dont know what it mean.
well does anyody here knows good rim repair shop in Los Angeles ? around downtown area?
thanks again!
Jay.
Old Jan 20, 2011 | 09:47 AM
yetti96's Avatar
yetti96
thanks again!
Jay.
If you read the link supplied after my first response, I was wrong and do apologize.
"On July 12, 2006 the size of wheel bolts was changed from M12x1.5 to M14x1.25. There exists a misconception that this change in wheel bolt size precludes fitting early OEM wheels on later model cars. This is simply not true as all OEM wheels have holes large enough for either size wheel bolt."
So basically I was wrong and you can use these.
Old Jan 20, 2011 | 09:53 AM
since041309
thank you yetti96!
SosoMINI
Nov 22, 2015 03:17 PM
Aug 12, 2015 01:24 PM
Accessory Products
Aug 11, 2015 12:37 PM
Aug 11, 2015 12:34 PM
