R50/53 is this sound a timing chain tensioner going bad or something else
Old Jan 14, 2011 | 12:55 PM
ViniD's Avatar
ViniD
Hi I was wondering what this sound maybe i have posted a video on youtube wondering if anyone can help me out. http://www.youtube.com/watch?v=H_rVlF0494g Thank you
Old Jan 14, 2011 | 01:44 PM
beken's Avatar
beken
That doesn't sound good. Hard to tell without knowing where the noise is coming from. Could be anything. My first guess would be an exhaust leak since the motor seems to be running fine in spite of the noise and you seem to be scanning (your camera) over the top and around the middle part of the engine. Catalytic converter maybe?
Old Jan 14, 2011 | 01:48 PM
ViniD's Avatar
ViniD
thanks, but i dont think its an exhaust sound its coming from the passengerside near the firewall
Old Jan 14, 2011 | 01:58 PM
beken's Avatar
beken
Is it on the passenger side, high or low? The crank pulley is low. The tensioner pulley is higher up and more towards the front a bit. It sounded like something is banging against something. Sorry if I can't be of much help.
Old Jan 14, 2011 | 02:32 PM
ViniD's Avatar
ViniD
It def on passenger side. I was wondering if u know if the '05 has timing belt or chain. thanks
Old Jan 14, 2011 | 02:36 PM
Rich.Wolfson's Avatar
Rich.Wolfson
Chain.
Old Jan 14, 2011 | 04:30 PM
CRoth's Avatar
CRoth
It's very possible that it's your tensioner bushings that have failed. It's pretty easy to check. Just jack up your passenger side and pull the fender liner off. With a light you should be able to see the bushings or lack of from underneith.
The other possible problem could be your timing chain tensioner. This is easy to replace but harder to test.
I hope this helped.
Chad
Old Jan 15, 2011 | 12:28 AM
vIPkOhH's Avatar
vIPkOhH
OMG...my 04 TSX is making the same noise...and I too got no idea what is goind bad...but the sound comes from the tensioner area!...hopefully some one here would help us out...!
Old Jan 15, 2011 | 06:02 AM
ViniD's Avatar
ViniD
I hope this helped.
Chad
Thanks I am gonna go give that a try today, i have to change my oxygen sensor so ill be underneath the car anyway. Thanks alot for ur help
Old Jan 15, 2011 | 06:20 AM
Detroit Tuned's Avatar
Detroit Tuned
Vendor - 15 Years
Yes it sounds like your chain tensioner. Have you been checking your oil and changing it every 5K? I have been finding they fail because of that. We stock them.
Chad
Detroit Tuned
https://www.northamericanmotoring.com/gallery/data/500/sig36.jpg
www.detroittuned.com ...Making MINIs faster since 2004 Who is DT??? FaceBook
Old Jan 15, 2011 | 06:38 AM
ViniD's Avatar
ViniD
just had my oil changed 3k miles ago, but we found it to be low the other day.
If the problem is the tensioner, what is involved with changing it? Does anybody have some technical data on this procedure and/or complete chain replacement?
Old Jan 15, 2011 | 08:42 AM
ViniD's Avatar
ViniD
also, it might be important to note that the noise is less evident, almost non existant, when the car is cold (oil pressure is higher). As soon as it warms up it makes the noise. It doesnt get worse with revving, its just a constant tapping.
Old Jan 15, 2011 | 02:29 PM
ViniD's Avatar
ViniD
thanks everyone for the help it was the timing chain tensioner, it was really easy to change after removing the passenger wheel well cover. Its right near the oil filter using 19mm bolt just replaced it.
Old Jan 15, 2011 | 02:48 PM
beken's Avatar
beken
Happy to know it's solved.
09R56
Nov 16, 2022 10:49 AM
TREX
Nov 2, 2019 07:31 PM
Svejk
Feb 24, 2019 12:18 PM
iamcamkeenan
Aug 10, 2015 03:31 PM
