Drivetrain Anybody doing interesting work on the Heads for the Mini's ?
Old Jan 4, 2004 | 04:56 PM
InfoSec's Avatar
InfoSec
All,
I was wondering if anybody was doing true mechanical work-overs on the Heads. I have been searching the Net and I have not been able to find a Speed shop that would do High Performance work on MCS heads (i.e. Titanium Springs & Retainers and Sodium filled valves). Has anyone come across a shop that does this kind of work???? Or maybe you have done on your MCS that would like to share their experiences.
Cheers
:smile:
Old Jan 4, 2004 | 08:36 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
There are several MINI owners that have done head work on their own.
See posts by mckinneymini
https://www.northamericanmotoring.co...c=21105&11
Quote:
The headwork was done by a local specialist who previously tuned Alfa Romeos. The ports were enlarged and polished and all that rough casting material was removed from around the valve guides, smoothing the airflow. Nothing other than polishing was done to the chambers so that we could retain compression ratios.
See MiniPilo
https://www.northamericanmotoring.co...mp;topic=20163
See jlm in
https://www.northamericanmotoring.co...mp;topic=20907
Old Jan 4, 2004 | 08:52 PM
10851CS's Avatar
10851CS
Check out Perfect Power (a sponsor).
Earl
Old Jan 5, 2004 | 07:04 AM
scobib's Avatar
scobib
The guy that does it here in Dallas, referenced by Mckinneymini in his post, charges $895 to work on your head, I believe. Bigger valves are additional.
Old Jan 5, 2004 | 05:37 PM
MiniPilo's Avatar
MiniPilo
We are about 2 weeks out from the head install for our car. This hear has had over 25 hours of just testing and prototyping done on it. We are also working on larger valves that are being sized up right now. We will be producing a .5mm larger intake valve, and a 1mm larger exhaust valve. We are working with DPR Racing out of California, and we will be the sole distributor of the mini products from this alliance. DPR RAcing is in the front of Honda Development, and has been around for a super long time. We will be getting the flow bench testing done soon, and will be getting HP numbers once we install. We are also having work done on the supercharger that will bring it above the JCW specs even with a new lubricant on the supercharger rotors allowing for cooler operations and more HP at lower boost. Once done with all of these , we will be venturing into the Piston area. We are looking to get pistons made to match the clover shape of the head, and boost compression slightly. We are hoping for some major hp gains with the pistons and still be able to keep the car smog legal. If you want more information on what we are doing, please give me an e-mail at Mini@thepilo.com And we can discuss what ever you might need done.
Thanks,
Dan
Pilo Racing
Old Jan 5, 2004 | 06:18 PM
vdubdoug's Avatar
vdubdoug
Sounds good Dan. Keep us informed!!!!
Old Jan 5, 2004 | 06:57 PM
jlm's Avatar
jlm
Pilo: when i get my rig back, we are gonna have to go at it!
Old Jan 5, 2004 | 07:00 PM
MiniPilo's Avatar
MiniPilo
It's on John.... :smile: I also have my Custom CO2 Sprayer on the way, and looking into some new intake stuff... I have so many things going on.. I don't know if I'm coming or going... that might be to your advantage though john.... But withthe 30" breaker that hit your head, we may be even now
Dan
Pilo Racing
Old Jan 5, 2004 | 07:54 PM
andy@ross-tech.com's Avatar
andy@ross-tech.com
Will you sell lubricant refills as well?
_________________
1/4 Mile Database
Old Jan 6, 2004 | 04:34 AM
MiniPilo's Avatar
MiniPilo
This Lubricant is a coating that is being applied to the rotors of the supercharger This is a superlebricant that does not need to be reapplied, or refilled. Basically if you were to get this on your hands, you would not be able to wash it off, and would have to sand a layer off your hand to make it not slippery again.
Thanks,
Dan
Pilo Racing
Old Jan 6, 2004 | 04:40 AM
05JCWS's Avatar
05JCWS
Pilo,
This is exciting stuff. Please keep us informed. I am extremely interested in both the supercharger and the head work.
Old Jan 7, 2004 | 04:56 PM
jazmini's Avatar
jazmini
Hey Dan,
Wow! heads, valves, pistons, etc. This is all good stuff for us future MC modders. Don't forget about us CVT types out here. Keep up the good work!
Old Jan 7, 2004 | 05:50 PM
InfoSec's Avatar
InfoSec
Dan please don't tell me that you are going to Teflon coat the supercharger impeler
Old Jan 7, 2004 | 06:02 PM
MiniPilo's Avatar
MiniPilo
It is not a teflon Coating, but a high tech lubricant that will coat the existing coating, allowing for cooler operation, and a more efficient charge.
Dan
Pilo Racing
Old Jan 7, 2004 | 06:11 PM
timj1231's Avatar
timj1231
I wonder if it's the stuff the sell in "ADULT PRODUCT" stores?
Old Jan 7, 2004 | 07:16 PM
MiniPilo's Avatar
MiniPilo
Lol... It would be a 1 time use for weeks of enjoyment if used for that...
Dan
Pilo Racing
The_Kid
Cincinnati MINI Club
Aug 4, 2016 02:40 PM
arf88
May 31, 2016 03:07 PM
phrza81
Oct 10, 2015 11:37 PM
MIminiclubman
Aug 5, 2015 09:14 PM
