Drivetrain Anybody doing interesting work on the Heads for the Mini's ?
All,
I was wondering if anybody was doing true mechanical work-overs on the Heads. I have been searching the Net and I have not been able to find a Speed shop that would do High Performance work on MCS heads (i.e. Titanium Springs & Retainers and Sodium filled valves). Has anyone come across a shop that does this kind of work???? Or maybe you have done on your MCS that would like to share their experiences.
Cheers
:smile:
Cheers
:smile:
There are several MINI owners that have done head work on their own.
See posts by mckinneymini
https://www.northamericanmotoring.co...c=21105&11
Quote:
The headwork was done by a local specialist who previously tuned Alfa Romeos. The ports were enlarged and polished and all that rough casting material was removed from around the valve guides, smoothing the airflow. Nothing other than polishing was done to the chambers so that we could retain compression ratios.
See MiniPilo
https://www.northamericanmotoring.co...mp;topic=20163
See jlm in
https://www.northamericanmotoring.co...mp;topic=20907
See MiniPilo
See jlm in
We are about 2 weeks out from the head install for our car. This hear has had over 25 hours of just testing and prototyping done on it. We are also working on larger valves that are being sized up right now. We will be producing a .5mm larger intake valve, and a 1mm larger exhaust valve. We are working with DPR Racing out of California, and we will be the sole distributor of the mini products from this alliance. DPR RAcing is in the front of Honda Development, and has been around for a super long time. We will be getting the flow bench testing done soon, and will be getting HP numbers once we install. We are also having work done on the supercharger that will bring it above the JCW specs even with a new lubricant on the supercharger rotors allowing for cooler operations and more HP at lower boost. Once done with all of these , we will be venturing into the Piston area. We are looking to get pistons made to match the clover shape of the head, and boost compression slightly. We are hoping for some major hp gains with the pistons and still be able to keep the car smog legal. If you want more information on what we are doing, please give me an e-mail at Mini@thepilo.com And we can discuss what ever you might need done.
Thanks,
Dan
Pilo Racing
Thanks,
Dan
Pilo Racing
It's on John.... :smile: I also have my Custom CO2 Sprayer on the way, and looking into some new intake stuff... I have so many things going on.. I don't know if I'm coming or going... that might be to your advantage though john.... But withthe 30" breaker that hit your head, we may be even now
Dan
Pilo Racing
Dan
Pilo Racing
_________________
1/4 Mile Database
This Lubricant is a coating that is being applied to the rotors of the supercharger This is a superlebricant that does not need to be reapplied, or refilled. Basically if you were to get this on your hands, you would not be able to wash it off, and would have to sand a layer off your hand to make it not slippery again.
Thanks,
Dan
Pilo Racing
Thanks,
Dan
Pilo Racing
Dan please don't tell me that you are going to Teflon coat the supercharger impeler
arf88
May 31, 2016 03:07 PM
phrza81
Oct 10, 2015 11:37 PM
