R50/53 Boot wont open
Old Jan 2, 2011 | 11:55 AM
gabber's Avatar
gabber
Boot wont open
So today I decided to pressure wash my car after coming home from up north. It was nasty, full of salt, dirt, and it was just nasty. While I was cleaning the inside, I went to open the boot to clean it, and now it wont open with that button by the license plate not with the key. Does anyone know if these things have issues? I took the screws off and pulled it off to let it air out and dry if there is any water in it. I also read a few other post by not any luck.
Old Jan 2, 2011 | 12:14 PM
JWA's Avatar
JWA
Yep, they are known to have issues with the wiring in the handle that goes to the microswitch and the license plate lights getting wet and shorting. Mine just did it last week. Apparently people have had issues where it will just randomly pop open. Mine would pop open every time I turned off the headlights or running lights.
You're onto the right solution. Remove the handle and dry it out. Put it somewhere warm for a while and it should dry out and work again. Then do something to seal it up a bit to avoid future issues.
Old Jan 2, 2011 | 12:33 PM
gabber's Avatar
gabber
Ok I got it off and dried it with the air compressor. I hooked it back up and it didnt work. I turned the lights on to make sure it was hooked up right and it was. When the lights went off. It opened!!! I guess this is gonna be the temp way of opening my boot. Does anyone know where I can buy a new one???
Old Jan 2, 2011 | 12:37 PM
JWA's Avatar
JWA
You can buy the switch and seal separately, or the whole unit in black, primed, or chrome. Any dealer can get them, or you can order it through PenskeParts.com or the like. You're looking at $90-100 depending on finish.
But I wouldn't give up just yet. I couldn't see any water in mine either. I think the water wicks up somewhere small and tight. Use heat. I put it on the mantle above my fireplace for 3-4 hours and that did it. You could try using a heat gun if you're in a hurry. But I bet it will work when fully dried out.
Old Jan 2, 2011 | 12:38 PM
JWA's Avatar
JWA
Also, I assume that you're familiar with the pull handle under the center of the rear seat, right?
Old Jan 2, 2011 | 12:40 PM
gabber's Avatar
gabber
I took the boot handle off and its sitting on my kitchen counter. I let it sit till tomorrow. I actually found the switch today when I was cleaning the car and I took the seat out. When I found it I was like WTF
Filmy
15
Jun 6, 2023 06:27 AM
67morris
Dec 1, 2015 12:53 PM
Classic R53
Nov 5, 2015 01:39 PM
MINI MX
Sep 25, 2015 07:28 AM
MiniUnz
Sep 14, 2015 11:11 AM
