R56 Complimentary Inspection
Old Dec 8, 2010 | 08:14 PM
MiniBOL's Avatar
MiniBOL
I have a certified 07 MCS with extended warranty. I just received a complimentary inspection flier from my local Mini Dealer. I am currently at 30K and just changed my oil. Last time the Mini was at the dealer was in September because of the chain tensioner which was replaced. Anyone receive this kind of flier from your Mini Dealership? If so I am wondering what kind of free inspection will be expected? Is it even worth it to take the car in?
Newbie to Mini and since my chain tensioner had to be changed I'm leaning towards taking the car in since its a "free inspection".
Thanks in advance for any of your input!
Old Dec 8, 2010 | 08:27 PM
MINIxB's Avatar
MINIxB
they usually just check it out and make sure nothing is leaking or broken and check the brakes and tires to see if they need replaced. Sometimes they change the air filter too.
Old Dec 8, 2010 | 08:56 PM
MiniBOL's Avatar
MiniBOL
i see. i guess its worth taking it then since its free. I'll just see what needs replacing and decide anything that needs to be replace
Old Dec 8, 2010 | 09:06 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
Little FYI, most of the time these "free inspections" are just a scam to get you into the dealer, then they'll be telling you that you need these other services like rotate and balance, fuel inject clean, p/s flush, nitrogen filled tires and such.
Also if a MINI is under warranty it is against MINI USA policy for a technician to find anything wrong with your car unless you complain about it or it's a safety concern. They call it upselling warranty, cause if they were allowed dishonest techs would claim all this stuff was wrong with your car and they fixed it just to get paid.
Old Dec 8, 2010 | 09:21 PM
MiniBOL's Avatar
MiniBOL
Thanks for the FYI!
Old Dec 9, 2010 | 05:26 AM
yetti96's Avatar
yetti96
I did Inspection 1 and it consisted of a systems check and a car wash. The tech asked if I wanted to get my tires rotated and balanced. He said the stock weights were on it and in 30k miles they could use a re balancing. I kindly declined and went along my merry way. FWIW, I did notice all of the seat belts were plugged in, even the rears when i got it back.
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
gknorr
Dec 26, 2016 09:38 AM
vulkandino
Oct 31, 2015 08:29 PM
pkillur
Tires, Wheels, & Brakes
Oct 1, 2015 03:59 AM
Sep 10, 2015 03:36 PM
