what tire size for 17x7 et 37?
Old Dec 6, 2010 | 08:29 AM
tmoney's Avatar
tmoney
I'm putting some 17x7 et37 wheels on my 06 mcs. Will 205/45s work without major rubbing issues? The car is on the stock suspension.
Old Dec 6, 2010 | 08:36 AM
Creeve's Avatar
Creeve
205/45 will work fine. those wheel specs at stock height aren't really restrictive in terms of rubbing.
Old Dec 10, 2010 | 12:51 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
205/45-17 will not rub.
215/45-17 will not rub with stock suspension.
215/40-17 would be smaller tire diameter and give more wheel gap.
You will start to get into trouble if you drop your suspension by 1" especially in the rear. That is due to the et 37mm aggressive offset for the rear.
If you use coilovers you can adjust ride height to fit any tire.
Kimolaoha
Dec 5, 2020 09:32 PM
kazyn
Oct 25, 2019 02:34 PM
DrFraserCrane
Aug 30, 2015 01:11 PM
col127
Aug 21, 2015 02:11 PM
Edgar78
Aug 15, 2015 05:33 AM
