How are my non runflats burning so much tread?
Old Dec 6, 2010 | 07:58 AM
koveras's Avatar
koveras
I bought some Michelin Pilot Sport AS/Plus rated at 45000 miles last January. After 15,000 miles, they are already almost bald. I drive a 2009 convertible JCW and I have taken it to the mountains of NC a few times and played, but ive never tracked it and most of my driving is commuting to work. My commute is not overly twisty and I often have people in the way so im not driving overly fast. What could possibly be causing my car to eat tires that quickly? Theyre mostly worn on the outside edges, but i cant find anything wrong with the car. If anyone has a clue, please share it!
Old Dec 6, 2010 | 08:34 AM
Creeve's Avatar
Creeve
Sounds like a poor alignment to me.
Old Dec 6, 2010 | 08:42 AM
Vollgas's Avatar
Vollgas
What pressure are you running?
I have the same tires, 32psi and I've got 12k on them and plenty of tread left.
Old Dec 6, 2010 | 09:33 AM
ZippyNH's Avatar
ZippyNH
The alighnment is somewhat suspect, as is the preassures, but...
Lots of turns, and depending on the blacktop/concrete surface, it is pretty easy to go through tires much faster then the manfactures usual optimistic treadlife guess. I'm thinking a high hp car (JCW), twisty roads, and rough pavement (it is groved in mountainous areas, and areas that get lots of rain to increase traction....this increases tire wear, especially if the driver is steering aggressively).
Still sucks they were used up so fast....hopefully you will get some $$ when they are prorated under warrenty!! Expensive tires to have wear out quick!!
Old Dec 6, 2010 | 09:47 AM
koveras's Avatar
koveras
The shop put 37 psi in them and ive kept them there. they wear on the outsides a decent bit more. My runflats did the same, though. Maybe i should get that checked out. My co-worker drives a Subaru WRX and he says his tires are wearing a lot less and he admits to driving much harder than i do.
freeman727
Dec 10, 2017 04:00 AM
bahman
Feb 14, 2016 10:29 AM
semibreve42
Oct 2, 2015 09:06 AM
aldito2
Sep 30, 2015 10:44 AM
AoxoMoxoA
Tires, Wheels, & Brakes
Sep 30, 2015 06:00 AM
