Suspension lowering question
thanks, -2.5 is way too much for a DD. If this was for a dedicated track car, that would be fine.
Sorry, I've had a rough day. Yes get rear control arms and dial in -1.5 or a little less rear camber for better handling and tire wear. You must get an alignment either way.
- andrew
1.2 is a lot for these cars on springs.....they have very little bump travel. I guess we're talking about different things though.
-2.5 in the rear is too much for the track.
- andrew
- andrew
Even with the 5/8" drop of the JCW suspension on my 06 MCS, I can only reduce the amount of rear negative camber to about negative 1.5-1.6 with the stock adjustment. So if you drop any lower than about 5/8" you will need aftermarket adj lower control arms to get the negative camber into the -1.5 range that is prefered by most people.
silence2-38554
Nov 12, 2015 09:39 AM
loop4re7
Oct 5, 2015 09:53 PM
Minibeagle
Aug 13, 2015 10:00 AM
